  • Guests: 53
Madgyver (40)
mike0t4ever (43)
Ken M. (40)
tesla500 (39)
Fabi (32)
hatto018 (40)
10/18 seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
IXDD414CI obsolete new replacement IXDD614CI
teravolt
Wed Nov 09 2011, 02:40AM Print
I have been frustrated like some others trying to find some TO-220-5 type mosfet drivers. it had been a while since I bought some so I had to make a search and this is what I found. apparently IXYS is now CLARE semiconductors for drivers hear is the link.
also others have TO-220-5 drivers just go hear
and go to •PMIC - MOSFET, Bridge Drivers - External Switch, and go to TO-220-5 under package/case
I am happy they still make them since they are needed for some of my PCB's
Wed Nov 09 2011, 03:17AM
It appears IXYS is the parent and CLARE is the child corp... i hope they dont screw me out of some of the DIP case types i need.
Dr. ISOTOP
Wed Nov 09 2011, 07:52AM
Patrick wrote ...
There's no point in using the Clare gate drivers if you're using a DIP package, seeing as TI samples the UCC37322 (and 'tis semi-ethical for you to get them too; last time I checked you could fill out "student project" on the form).
You want to use the Clare stuff when you need the higher dissipation of the TO-220 package.
Wed Nov 09 2011, 08:14AM
bwang wrote ...
Patrick wrote ...
im hoping to be able to get the IXBD4410PI 14 pin DIP, and the IXBD4411PI 14pin dip for sometime as i have boards and devices already made for awhile out.
teravolt
Wed Nov 09 2011, 02:30PM
I haven't tried them yet but there is 30A IXDD630CI
I wonder if they have a lower on resitance to get the 30A rating. hay Patrick aren't the ixbd4410 and 4411 the half bridge drivers how do they work out for you?
Wed Nov 09 2011, 06:22PM
teravolt wrote ...
They work real well, i hoping to continue using them as long as their made.\
As for your resistance comment, i belive the silicon doping and die geometry is what allows the fast charge change, in these devices. Not just a lower and lower Rds.
