  • Guests: 34
Madgyver (40)
mike0t4ever (43)
Ken M. (40)
tesla500 (39)
Fabi (32)
hatto018 (40)
10/18 seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
Capacitor tester crapped out
Chip Fixes
Mon Nov 07 2011, 11:31PM Print
My capacitor tester on my DMM isn't working anymore. Should I buy an actual capacitor tester? or should I just buy another DMM with a capacitance meter function? Cheaper is better as long as it's accurate.
Tue Nov 08 2011, 01:38AM
Camp Badger wrote ...
I murdered my LCR meter, then bought a cheaper, chinese one that only does C, havent regretted it yet, seems as accurate as the more expensive ones.
radiotech
Tue Nov 08 2011, 08:50AM
Never, NEVER work around high voltage with your instruments !
(borrow someone elses)
Ash Small
Tue Nov 08 2011, 05:49PM
Same thing happened to me.
I just use a known inductance, sig. gen. and 'scope now.
Electra
Tue Nov 08 2011, 11:07PM
Personally I think a separate LCR meter is better, The L function is useful to have though admittedly not used as much. Many also give a choice of measurement frequency higher is better for measuring very small capacitances, (10’s of pf) something my last multimeter couldn’t do very well.
If I was buying one now I’d try to find one with ESR measurement as well, to test suspect electrolytic’s Also check what the highest range is if you need to check really big caps.
I don’t know what the really cheap ones are like, but I’d probably be a bit wary of them too.
Chip Fixes
Wed Nov 09 2011, 12:59AM
Alright, thanks guys
testtest
Wed Nov 09 2011, 03:01AM
testtest Registered Member #3271 Joined: Mon Oct 04 2010, 02:29AM
Electra wrote ...
"The L function is useful to have though admittedly not used as much" unless you work on speakers crossovers and such...
