  • Guests: 57
mazilli driver for a tesla coil
tritium
Mon Nov 07 2011, 04:29PM Print
tritium Registered Member #2591 Joined: Fri Jan 01 2010, 11:58AM
hello guy's,
I was thinking of making a tesla coil of +/- 4 mhz and use the mazilli driver, I have verry fast mosfets from ixys (ixfn55n50f) +verry fast mosfet drivers (ixys deic420)
also I wan't to make it audio modulated in high quality, if this is not possible, or I can better take another road, please tell me.
edit: sorry, it is in the wrong thread, used to be in the tesla coil threads.. rolleyes
Marko
Mon Nov 07 2011, 10:00PM
Hi tritium
mazzili driver at high frequencies and especially high voltages is problematic, and is most likely going to go boom instantly if you attempt to use the diode feedback and no overcurrent protection of any kind.
To get the maximum chances of this working, try using voltage feedback from the primary tank circuit using a transformer and feed this into a fast comparator, then into DEIC's (IXDD414's will probably work for this frequency too) which then drive the mosfets... for overcurrent protection, put a shunt between mosfet sources and GND and use a LM311 and NE555 to disable the drive in case of fault.
You'll also likely need some startup oscillator to get everything going.
Marko
Tue Nov 08 2011, 03:04AM
Where did you get the deic420's and for how much? I have been having issues getting them in small quantity.
If I had such components, I would use a conventional class E design. Less chance of it blowing up and better switch utilization I believe.
tritium
Tue Nov 08 2011, 03:32PM
@weston
I got the deic420 from farnell/newark for 30 euro's
