  • Guests: 54
Sanchez (36)
Knarvel (13)
10/17 mike0t4ever (43)
10/17 Ken M. (40)
Identification help
earth3
Sat Nov 05 2011, 10:33AM Print
earth3 Registered Member #3721 Joined: Sun Feb 27 2011, 04:43AM
hey guys i got this transformer and a capacitor. but i cant figure out what kind of transformer it is and the cap too. the cap got 4 pins. im only familiar with 2 pin caps anyone knows how to connect this cap?
CAPACITOR IMAGE:
TRANSFORMER IMAGE:
any help is welcome to identify these parts.
Tetris
Sat Nov 05 2011, 02:17PM
Not sure about the caps, but the transformer looks like a tapped MOT. Could be wrong. O_O
Ash Small
Sat Nov 05 2011, 03:39PM
I've had electrolytics like this, where one terminal is negative, and the others are positive, like three capacitors in one package.
One I had even had different values.
I can't guarantee that this is what yours is, but yours seems to only have one negative terminal.
Sat Nov 05 2011, 03:56PM
I cant help you much with the transformer, it looks likea normal iron core one though.
As for your cap, check the capacitence (if you have a meter) i think your cap as three 1.15uF caps (1, 2 and 3)inside it all tied in common with the (-) pin. if all three have the same capacitence then youll also have to check for continuity, none of the pins 1,2 or 3 should be low in resistance if there are 3 caps inside.
radiotech
Sat Nov 05 2011, 07:15PM
The caps have 4 lugs so they can be secured to a pcb without rocking. Something
has to hold the metal can in place. You wouldn't it launching itself. amazed
Sat Nov 05 2011, 08:01PM
radiotech wrote ...
thats why i suggested the continuity check between pins 1, 2 and 3, internallly they may be seperate plates, or all tied to the case.
earth3
Sun Nov 06 2011, 03:42AM
when i connected - and 1 pin it showed increasing resistance. i tested continuity but nothing showed up.
i charged it with a 4 volt battery through - and 1 pins. it discharged through the same pins. but the discharge time was very long. i think it is because of low volts.
Sun Nov 06 2011, 04:02AM
I think this is what you have...
1320552142 2431 FT127736 Sam 0460
3 caps in the same orange tubular body.
earth3
Tue Nov 08 2011, 05:42AM
but it doesn't show anything if i connect it with other pins
