  • Guests: 47
Sanchez (36)
Knarvel (13)
10/17 mike0t4ever (43)
10/17 Ken M. (40)
Dented capacitors, are they ..."unsafe?"
Inducktion
Mon Oct 31 2011, 02:39PM Print
Are dented electrolytic capacitors generally unsafe? I got a slightly dented cap, and I was planning on using them for a coil gun...so I'm worried something might go "boom" because of the dent.
And, is there any way of fixing a dent in a capacitor?
Also, what is the surge voltage rating of a capacitor mean?...
dude_500
Mon Oct 31 2011, 04:08PM
dude_500 Registered Member #2288 Joined: Wed Aug 12 2009, 10:42PM
I don't think they're considered to be extremely safe, but I have used many dented capacitors (large ones, if it's a tiny little through-hole cap, just throw it out, not worth it) and I have never had a problem. I usually charge it up slowly standing back if it has never been used and is dented, but in general after that I just trust that it'll be fine. An advantage to those big can capacitors versus the larger of "small through hole caps" is that they are very well vented and are extremely unlikely to explode producing hazardous shrapnel. There are several videos of torturing big can-size capacitors, they just sit there for a few minutes then the vent plug pops out and steam pours out quite unspectacularly.
radiotech
Mon Oct 31 2011, 05:43PM
Any sealed capacitor might have a high internal pressure, so its best to be aware
that whats inside, gas or fluid might escape through the weakest point, usually the
terminal end. (wear eye protection) "Booms" are caused by too much heat, building
up too fast, because the rate of rise of current is too high.
