ZVS MOSFET question
cbfull
Thu Oct 27 2011, 08:07PM
Registered Member #187
I notice that it says on the ZVS schematic that the MOSFET must have an Rds of 0.150 Ohms or less, but a lot of HVers seem to have no trouble using the IRFP460 which has Rds of 0.270 Ohms. What sort of problems could a higher Rds cause? I've been digging around for a few days to find an answer and haven't found any comments about that.
I ask because I have a couple of sleeves of the IRFP460's
Myke
Registered Member #540
As far as I know, the only downside of a high Rds is the MOSFETs dissipate more power as they drop more voltage. This makes your driver less efficient but it should still work. Just make sure you use a suitable heat sink so they don't get too hot. Remember, the MOSFETs need to be electrically insulated from a common heatsink otherwise you short out your driver.
