  • Guests: 62
Voltage multiplier first capacitor gets AC?
JohnL
Fri Oct 28 2011, 11:56AM Print
JohnL Registered Member #3842 Joined: Thu Apr 21 2011, 12:19PM
I was simulating a CW multiplier in NL5 and I noticed that the first capacitor seems to get exposed to AC while the rest get DC, I found this thread which says otherwise:
http://4hv.org/e107_plugins/forum/forum_viewtopic.php?110744.post
Here is my schematic and my results, It is a voltage on each capacitor with respect to time graph.
1319802989 3842 FT0 Cw Multiplier Diagram
1319802989 3842 FT0 Cw Multiplier Transient
Can anyone explain this result?
Daedronus
Fri Oct 28 2011, 02:12PM
You have a diode in series with it, so, no, it's not AC
Fri Oct 28 2011, 03:49PM
The first capacitor sees ac current. Under normal operational conditions it should see a dc voltage with small ac ripple, but if the multiplier is badly designed or heavily loaded, the voltage on that cap can fall to a negative value.
JohnL
Sat Oct 29 2011, 02:54AM
i increased the capacitance the the first capacitor and put a resistor in series the the multiplier and it doesn't get reverse voltage anymore, thanks
