  • Guests: 48
Sanchez (36)
Knarvel (13)
10/17 mike0t4ever (43)
10/17 Ken M. (40)
PING G20 Drivers Review
golfforsales
Sat Oct 22 2011, 06:33AM Print
golfforsales Registered Member #4157 Joined: Sat Oct 22 2011, 06:30AM
If you want to perform well and get good score on the golf court, taking the latest golf clubsGolf For Sales here,such as PING G20 Driversback to put in your golf bags.
The PING G20 Drivers has a heavier head than PING G15 Drivers (7 grams more than standard) for greater force at impact.Additional backweighting and a more elongated face shore up misses.In total, G20 launches shots 0.75 degrees higher than G15,with 200 rpm less spin and 1 mph faster ball speed on center hits, which adds up to five yards more carry and roll.
The external weighting of the G20 driver helps the golfer to swing a heavier clubhead at the same speed with a high moment of inertia,that result in launching the ball higher with low spin for maximum distance and accuracy.
The PING G20 Drivers G20 Driver pushes distance to the limit without sacrificing forgiveness off the tee by utilizing an external weight that optimizes the center of gravity position to generate high launch and low spin.The G20's longer,large, variable-thickness clubface creates forgiveness and power across the entire hitting surface.
