  • Guests: 36
Sanchez (36)
Knarvel (13)
10/16 Sanchez (36)
10/16 Knarvel (13)
Boost Converters' issues
Inducktion
Tue Oct 18 2011, 12:44AM Print
I've made two boost converters, using the below chips;
Link2 one uses this, while the other uses Link2
I've noticed that whenever I plug in a...load, like, say, my ipod, the IC will start clicking, and the clicking is mimicked in the screen brightness of my ipod touch. This ...ripple, is preventing the ipod from charging corrrectly, and actually discharges it (which is bad, for obvious reasons) (also, yes, I have resistors across the data input/outputs of the USB port, as per instructions for making IPOD chargers)
They both are made to run off of two AA's, (though, I'm thinking 3 may be more realistic for the TI IC one)
When adding another load like 50 ohms across the regulator, it stops the flickering, and the ipod charges normally. However, for obvious reasons, this is wasteful of power, and with two AA's, that's really not a good thing. (
Also, another note, both have a 5 volt linear regulator (7805) on their outputs, as I've made the output voltage of them adjustable with a potentiometer. (don't want to kill any USB devices :) ) The TI IC one has a roughly 200 uH inductor (litz) wrapped on a powered iron core from a PC supply. The other one has a 100 uH inductor with standard magnet wire wrapped around a yellow powdered iron core. The TI one has 470 uF filter capacitance on the output, while the LM3578 one has 1000 uF.
Is there some way to get rid of this nasty flickering/ripple issue, asides from adding a wasteful min load?
ScotchTapeLord
Tue Oct 18 2011, 01:03AM
Um, perhaps you should not be using your ipod to test such a device, but that aside, you could use a diode in series with the inductor to prevent it from discharging your device. I'd get rid of the 7805 as it is probably being degraded when the input drops below the output as you've described. You can put a 5.1V zener diode in parallel to the load to help regulate but you should really be using the feedback loop to get the proper voltage.
Inducktion
Tue Oct 18 2011, 01:38AM
But Scotchtapelord, the problem isn't the output voltage; It's fine, it's just the ripple that's being the issue. For some reason that causes the ipod to "think" it's charging, when in actuality it's doing quite the opposite.
2Spoons
Tue Oct 18 2011, 03:34AM
Have you tried using Nationals Webbench simulator to test your design?
ScotchTapeLord
Tue Oct 18 2011, 04:32AM
Ripple is fluctuation of output voltage, so it is your problem. I don't see how the design could be sinking current from what you are charging, assuming you followed the asynchronous designs in the datasheet. What is the unloaded output voltage?
Inducktion
Tue Oct 18 2011, 10:54AM
I think I figured out the problem; It's going into discontinuous mode, because I guess the ipod touch is too light of a load for the regulator... I need a bigger inductor, which apparently will fix the issue.
Forty
Tue Oct 18 2011, 04:18PM
why not use a capacitor on the output to smooth it out?
Mattski
Tue Oct 18 2011, 06:03PM
Forty - The input-output voltage relationship changes when moving into discontinuous mode, and it can be difficult for simple controllers to handle both cases.
Inducktion, if you have this capability with your chips, you can try increasing the switching frequency which will tend to push you back into continuous mode. However, when the ipod is done charging the current will drop and it may go discontinuous again so you may wish to add a minimum load, or perhaps current sensing with a load that will switch on when you want to maintain voltage under low load conditions.
Inducktion
Tue Oct 18 2011, 07:33PM
okay, I fixed it! I just used a larger inductor and the ripple problems are gone. :)
