  • Guests: 30
Sanchez (36)
Knarvel (13)
10/17 mike0t4ever (43)
10/17 Ken M. (40)
CV and CC mode?
haxor5354
Mon Oct 17 2011, 01:36AM Print
how do power supplies know if they're in Constant Voltage or Constant Current mode?
is it done by detecting voltage sag? if the output voltage sags by X amount then its in CC mode? and if it doesn't sag then its in CV mode?
Mon Oct 17 2011, 01:46AM
Watching the voltage sag wont be useful in a regulated linear or SMPS.
It has a known Low ohm-resistance in series with the output, when a voltage appears too low across the Rs it stays in CV, when the Voltage across the series resistor rises to a trip point, the PS starts to lower the V to keep the current at the set level. Foldback current limiting can also use this method.
When you turn the Current set knob (on the front of a PS) your really changing the Op-amp that watches that series resistor, thus you can have variable voltage and variable current limit on some of the nicer full featured PS's.
haxor5354
Mon Oct 17 2011, 01:59AM
so the if the PS has a current knob, you can theoretically short it out w/o problems because the output current is limited to a safe value?
Mon Oct 17 2011, 02:08AM
Yes back in 2001 when i was doing analog/digital breadboard stuff at Ohlone College, i had a knob for CV and A knob for CC, when the load coditions changed you could hear a relay click on and off, and there was a Green and red LED to tell you which mode the PS was in, these SMPS's (the nice ones $$$) have an active load that cuts in at low load to stop high voltage pulsing and surging.
(and yeah some idiots shorted them out and wondered why they had 1.2 A at only 0.3 V. )
rp181
Mon Oct 17 2011, 04:06AM
Yep. I have a PSU like that. You can specify a voltage and a current. If the current draw goes above the limit, it switches into CC and reduces the voltage until that current is drawn.
