  • Guests: 61
Madgyver (40)
mike0t4ever (43)
Ken M. (40)
tesla500 (39)
Fabi (32)
hatto018 (40)
10/18 seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
Free running (no actual IC's or anything) switching regulator, and Battery Charger...
Inducktion
Sun Oct 16 2011, 09:01PM Print
Don't know if this works in real life, imo, but, it seems to in the simulation. (one thing I'm worried about is bad oscillations in the Mhz range)
And then, this, Link2 which I've tried in person, and it works charging a capacitor.
It runs by the comparator going high, turning the MOSFET on, and the JFET firmly off. As the capacitor/battery charges through the constant current transistor, the comparator will turn off once the reference is reached (in the schematic's cause, 1.39 volts). Once this happens, the mosfet is off, and the JFET turns on, changing the voltage reference down to .5 volts, preventing oscillations from hurting anything.
I actually got the free running switching regulator idea from the battery charger. :P
