  • Guests: 65
  • Most ever online: 441
    Guests: 441, Members: 0 on 01 Oct : 16:32
GhostlyFigures (36)
10/06 Ivan Kalafatic (17)
10/07 Pyromaniac (34)
10/07 Wavetuner (76)
Tips on probing high speed digital signals
rp181
Sat Oct 15 2011, 09:05PM Print
I have started working on LVDS data lines, but I am having trouble getting a good signal. I don't know if it is what actually is happening or just noise.
Right now it is 20mhz 300mv LVDS with a 1.5v common mode voltage, but it will go up to 85mhz. I am trying to eliminate long ground leads to the probe (10:1 passive, well compensated), but it still gives me lots of noise. It looks like noise, but my scope (agilent 3000x, 100mhz) tells me it is 20mhz, so I don't know if it is noise or an actual signal coming through.
Any tips?
EDIT: Here are some pics.
Here is the very very noisy LVDS line.
SixGE
Here is the input.
T7zIC
If I zoomout, and look at the peaks, it shows 25khz. So I think it is working, there is just massive noise. The noise is around 20mhz, which happens to be my clock frequency.
9GCb1
Background: This is from a chip that converts 28 bits of parallel data into 4 LVDS lines + 1 Clock LVDS. A receiver decodes it back into the 28 bits.
Sat Oct 15 2011, 11:10PM
Simple LC filter maybe? Sometimes the issue can be conducted noise from the power supply.
-A
Carbon_Rod
Sun Oct 16 2011, 12:32AM
LVDS lines may stop working if the signal pair trace lengths and or impedance mismatch.
Additionally, the signals for driving most panels usually operate above 100 Mhz, but note the ratio between the clock line to signal lines.
There are LVDS conversion driver chips that are used by many designers to bypass the hassle of emulated driver setups.
Good luck,
Rod
rp181
Sun Oct 16 2011, 01:30AM
You are spot on Carbon Rod. I do know I have impedance mismatch considering I am using a breakout board and a breadboard, but I was hoping to see something for the sake of testing before having a board fabbed.
That document is excellent, I am using the CameraLink interface. So that means right now I have data at 135Mhz, too much for my 100mhz scope. At 85mhz thats going to be 595mhz of data, I guess I will be testing blind!
Thanks,
G.
Sun Oct 16 2011, 10:16AM
Scott Fusare Registered Member #531 Joined: Sat Feb 17 2007, 10:51AM
You might try a "Z Probe". Easy and cheap to build, almost completely eliminates ground lead exacerbated probe resonance issues. The differential balanced version would be best for LVDS probing but the single ended version should get you where you want to go.
Doug Smith has a construction article on his site - Link2
Howard Johnson also has much useful info on this topic - Link2
Scott
Mon Oct 17 2011, 12:55PM
Probably a small rf transformer, or isolating balun would be best I think.
Wind 2x a few turns on a type 61 ferrite or -6 or -7 toroid.
