  • Guests: 30
HV, low current measurement
John R
Fri Oct 14 2011, 08:16PM Print
John R Registered Member #4058 Joined: Wed Aug 17 2011, 10:14PM
Hello,
I am building an apparatus to measure corona discharge in an N2/O2 mixture. To produce the discharge, I will have a power supply putting out ~15 kV and a high voltage resistor to reduce the current to the micro to milliamp range. My question is, how can I effectively measure the current? Can I use a high voltage probe, and just directly hook it up to an ammeter that measures down to microamps? I'm not interested in building any extremely complicated setup. I have a pretty open budget, so if it's easier to buy something commercial rather than build it, I would most likely go for that.
Thanks!
Pinky's Brain
Fri Oct 14 2011, 08:56PM
Buy a cheap analog multimeter and put it in series with the cell at the ground connection?
PS. you are going to be burning ~99% of your power in the ballast resistor ... if the HV connections are in air you are going to be losing current through there though, so knowing the current in the cell won't tell you how much power you're putting into it (cause you won't know the voltage across it).
Jamie Cansdale
Sat Oct 15 2011, 12:43AM
Jamie Cansdale Registered Member #3904 Joined: Sat May 21 2011, 10:32AM
I like my 1mA moving coil meter for measuring corona current. You can find them all over the place on eBay.
