  • Guests: 44
Disposable camera transformer driver
HDF49
Fri Oct 14 2011, 07:51PM Print
HDF49 Registered Member #977 Joined: Thu Aug 30 2007, 06:57PM
I got given 10 or so disposable cameras, I want to wire 4 of the transformers up (2 pairs in parallel put in series) to go into a cw to get about 8-12kv for a sgtc. I just haven't a clue on how to wire them up, does anyone know a good driver circuit for them from the components on the board (I think I have 4 of the same boards, but a few are different, does this matter?) and when i get them to work should I use 4 drivers and transformers, or just one driver? Thanks in advanced.
currentkills91
Fri Oct 14 2011, 08:32PM
Here's a thread all about a camera flash tesla coil, all you have to do is search around ;) - Right Here
HDF49
Fri Oct 14 2011, 08:49PM
currentkills91 wrote ...
I've seen that and read through it many, many times and I'm still a bit miffed on how to wire up the transformers.
Fri Oct 14 2011, 09:28PM
Are you understanding the insulation requirements on the secondary?
Are you needing help phasing the primaries?
I dont know what your asking help for.
As for your driver questions my advice is a 555 with a FET to get something working, then go from there as needed.
HDF49
Fri Oct 14 2011, 09:46PM
Patrick wrote ...
I'm aiming to get the transformer running separate from the board but using the components already there (transistor diode and resistor?) I know it can be done I'm just not sure how to isolate the driving circuit from everything else.
Sat Oct 15 2011, 12:56AM
i guess youll need to measure a whole lot of things, then with an o-scope.
kimbomba
Sun Oct 16 2011, 01:09AM
kimbomba Registered Member #3854 Joined: Fri Apr 29 2011, 03:45AM
fight fire with fire wrote ...
Yep, me too, nowhere in the thread says how the transformers are wired
Sun Oct 16 2011, 02:50AM
You have to phase the primaries right or it wont work. personally i think a flyback or iggy would give you greater voltage and power at more reasonble driving conditions,
