  • Guests: 32
GhostlyFigures (36)
10/06 Ivan Kalafatic (17)
10/07 Pyromaniac (34)
10/07 Wavetuner (76)
Suggestions for a low-interference smpsu please.
Wed Oct 05 2011, 11:21AM Print
I'm (very) slowly designing/building a hf transceiver
a part of it needs to be an inverter
Input : 12 V lead-acid battery, VRLA or automotive.
Output : 28 Vdc at up to 5 Adc for the hf Power Amplifier.
(ssb, 'speech' power demand)
I want to minimise electromagnetic and electrical interference to the rest of the transceiver.
I considered 'royer' types but the component values are impractical,
so I'm going for a hard-switched push-pull forward converter
I found a nice big Mullard pot core
(FX2243..don't look for data on this modern internet)
and some Litz wire for winding, I've got a couple of 80V 90A TO220 mosfets Link2 and a dual schottky rectifier and TL494s etc.
(may change from TL494)
The output inductor will be a gapped pot- or EI-core
and I've got some electrolytic capacitors on order.
Anyone have any experience with low-noise smps?
I need hints, tips and tricks!
(I've read quite a bit)
e.g. I thought maybe a 32,768 Hz fixed frequency might help identify spurious frequencies, or maybe a frequency offset pot to move 'spurs'....
It's only a small part of the transceiver but possibly a source of difficult problems.
The inverter should fit on a 100 x 160 mm card in a 19" rack.
Hand-wired on a matrix board, so not too complex.
Any hints, tips or tricks?
Wed Oct 05 2011, 02:21PM
I think what you want is a fixed on time variable off time, so PFM. that will make the noise easier to isolate.
WaveRider
Wed Oct 05 2011, 07:56PM
Hi Sulaiman.. Perhaps the best way to reduce noise on the output of an SMPS is to set the SMPS output voltage just above your required voltage and follow the SMPS with a low-dropout series pass regulator. This can provide in excess of 60dB of noise isolation as the LDO strips the ripple off the SMPS output.. The only drawback is the efficiency loss through the series regulator. However, the alternative is using thumping big inductors and capacitors which will decrease efficiency anyway, as well as destroying the output voltage regulation because of inductor series resistance.
If you are building the transceiver, use a further layer of regulation on all frequency sensitive subsystems (PLLs, VCOs, etc.). If you can tolerate the efficiency loss, an extra layer of regulation on your transmitter final amplifier will keep power supply spurious out of your transmit signal.
Have fun!
Wed Oct 05 2011, 08:25PM
Patrick, I get the 'fixed on time' PFM scheme, thanks, I'll consider it ..... which ic does pfm?
WaveRider, a 5A ldo linear regulator, good idea but probably a bit too much stuff for this project but I'll keep it in mind if required. thanks.
Wed Oct 05 2011, 10:06PM
Sulaiman wrote ...
Shit. I was afraid youd ask me that! cheesey
Ill look then post here again, GTG to school noww.
2Spoons
Thu Oct 06 2011, 01:22AM
Look at some of the Cuk topologies. There are some clever versions using coupled inductors that can give you zero (yes really!) input or output ripple. Also ZETA for very low output ripple, or SEPIC for very low input ripple.
If its harmonics that concern you you might try a quasi-resonant approach.
IF you are interested in only a small portion of the HF band then careful selection of operating frequency can put the harmonics outside the area of interest - and also outside the IF frequency. I used this trick to good effect when picking a microprocessor crystal for a GPS tracker I designed.
WaveRider
Thu Oct 06 2011, 07:52AM
A search of the Farnell site yields this e-z to use 5A LDO with 1V dropout... (atho' 28V is pushing the limit on this device)
]lt108x.pdf[/file]
Since you are designing the transceiver from the ground up, a dedicated power supply with multiple regulators that provide 3.3V, 5V, 28V, and any required negative voltages is recommended. This can be powered by your 12V battery.
radiotech
Thu Oct 06 2011, 07:27PM
Two comments. The transceiver has lower power requirements on receive.
On transmit your RFI concerns are less.
Make two power supplies. low, easily shielded.
High. Less shielding.
When transceiver sends, switch both on.
History, old military units kicked in a dynamotor on transmit, otherwise operated on
a vibrator pack.
2Spoons
Fri Oct 07 2011, 12:29AM
WaveRider wrote ...
Linear regs are generally crap at rejecting signals over 10kHz, unless you can find something a bit special. The GBW product just isn't enough to provide any decent attenuation at MHz frequencies. Careful design of the SMPS is required first, to minimise generation of interfering signals - not just harmonics of the switching f, but also parasitic ringing, which can be pretty bad in some topologies.
That datasheet you posted shows rejection at 100kHz is down to about 25dB, and falling at ~20dB/decade.
Fri Oct 07 2011, 01:01AM
2Spoons wrote ...
WaveRider wrote ...
I was about to say the same thing. I think a good design will be most of the battle.
