  • Guests: 37
williamn (48)
ReddyK (57)
Birdman (31)
12/14 M.A.D. (32)
12/15 marko666 (58)
12/16 Will T (16)
damaged oscilloscope
kimbomba
Mon Oct 03 2011, 02:54AM Print
kimbomba Registered Member #3854 Joined: Fri Apr 29 2011, 03:45AM
This oscilloscope is not functioning properly, the display shows what you see in the photo. Any idea of what can be the cause, can it be repaired? the owner wants $30. thanks in advance.
1317610455 3854 FT0 Scope
radiotech
Mon Oct 03 2011, 07:17AM
It appears that something in the horizontal stage is limiting the deflection.Put the scope into X-Y
mode with no inputs attached, try and move the dot around the screen with the vertical and
horizontal position controls. This may be a transistor problem.
The scope is fairly limited in usage, it has only 15 Mhz. I found it in a 1975 HP catalog here.
Parts may be an issue. The scope was made for TV repair use, among other things.
It seems a lot of money for 35 year old non functional scope. However, it may be
a simple problem.
AndrewM
Mon Oct 03 2011, 06:12PM
The price isn't very good, IMO.
I bought a Tektronics 468 scope (100MHz analog w/ a 10MHz DSO module) with some dried PSU caps for $50.
