  • Guests: 43
Madgyver (40)
mike0t4ever (43)
Ken M. (40)
tesla500 (39)
Fabi (32)
hatto018 (40)
10/18 seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
What to do with a dead mot, and I need another one.
Inducktion
Sun Oct 02 2011, 02:24AM Print
I somehow managed to stab my primary on my mot with a flathead screwdriver whilst attempting to fix it.... Now the primary is ruined, what should I do with it other than throw it away? I can't rewind another primary, I don't have any wire fit for the job.
Sun Oct 02 2011, 02:58AM
If youve got a jet-ski or raft, now you have an anchor!
Sun Oct 02 2011, 03:09AM
Just buy some magnet wire and rewind.
Mattski
Sun Oct 02 2011, 03:13AM
The primary of a MOT is usually reasonably thick wire, it might be possible to do surgery and repair any shorted sections by cutting away the damaged area and soldering in new wire around any shorts or breaks, especially if the damage is only on the outer layer of the windings.
radiotech
Sun Oct 02 2011, 04:12AM
If you had driven the screwdriver into your hand, you could have joined the electricians union.
amazed!
Sun Oct 02 2011, 04:37AM
radiotech wrote ...
amazed!
I totally agree cheesey !!!
was it this bad?
1317530230 2431 FT125358 Mot
cause i fixed it, though it was a pain in the ass!\
WireTronic inc, (wiretron.com) might give you a free sample long enough to do the whole thing.
copper plated aluminum wire is the worst.
Luceš
Sun Oct 02 2011, 01:24PM
Luceš Registered Member #4108 Joined: Sun Sept 25 2011, 11:43PM
you could use it as a ballast, while building my vttc this summer... I was drilling wholes for wires and my drill pushed through the cabinet and stabbed my filament transformer's (rewound mot) primary angry so then I had to make another one mad
Dr. Slack
Sun Oct 02 2011, 07:32PM
Saw all of the remaining primary off and sell it for scrap copper, then put a dozen turns of heavy insulated wire on there as a new 12v primary. Et viola, a 12v to 2kV transformer needing only a 555 and a low voltage high current H bridge to drive it.
Microwatt
Sun Oct 02 2011, 08:22PM
Microwatt Registered Member #3282 Joined: Wed Oct 06 2010, 05:01PM
why not get another transformer. get outside on garbage day and look around
Forty
Sun Oct 02 2011, 09:59PM
If the primary wire is solid copper then it might be worth salvaging. I've been using copper mot primary wire to make lots of beefy inductors and coils. If the wire is aluminum, then it would probably be best to just scrap it and look for another mot (the secondary could still be used as a ballast.)
