  • Guests: 39
Sanchez (36)
Knarvel (13)
10/16 Sanchez (36)
10/16 Knarvel (13)
ZVS Welding inverter.
MArked One
Sat Oct 01 2011, 07:14AM Print
MArked One Registered Member #3688 Joined: Mon Feb 14 2011, 07:39PM
Greetings.
I am looking to construct a very simple stick welder.
I am thinking of using a ZVS driver to provide low voltage, high current and this weld with the device. Sorta like a solid-state MOT welder.
The questions are: What mods (aside from HV fets) will I need to carry out on the zvs for it to run 'off the wall'? Is this idea plausible to create? What size/type of ferrite core should I use?
If anyone can answer these questions, I will much appreciate it.
Kind Regards,
Ivan Kozlov.
Inducktion
Sat Oct 01 2011, 03:10PM
From what I've understood, so far, is the ZVS driver loves to go into a parasitic oscillation at voltages above 60- 70 volts. Why? No idea. You would need to modify it somehow to prevent it.
Doubl3 Helix
Mon Oct 03 2011, 05:33PM
Doubl3 Helix Registered Member #1548 Joined: Mon Jun 16 2008, 09:22PM
Has anyone done any tests to figure out why exactly this occurs?
Ash Small
Tue Oct 04 2011, 10:42AM
Why not go for a full bridge?
You can get IGBT's and gate driver IC's specifically designed for welding inverters.
I'll try and find some links, but I've mentioned them before in recent threads.
Daedronus
Tue Oct 04 2011, 11:01AM
What's special in a gate driver for a welder?
MArked One
Tue Oct 04 2011, 05:51PM
Greetings.
Thank you for all the feedback so far. If anyone has a schematic or datasheet I can use as a starting point, I would much appreciate it. I was thinking of using a modified version of uzzor's multipurpose inverter to run a low-voltage, high current HF transformer. Any feedback on this idea?
Kind Regards,
Ivan Kozlov.
Daedronus
Tue Oct 04 2011, 09:30PM
What I do know is that welders are constant current SMPS, half or full bridge, since a resonant SMPS is a bit harder to regulate.
I'm also working (slowly, very slowly) towards a SMPS welder.
It's built as a full bridge controlled with a UC3843. The current limit is pulse by pulse limit, sensing the current with current transformers in the primary.
It works OK right now after dealing with a lot of EMI that messed with the controller IC but I only tested it up to 40V input.
I need a variac to go slowly up to line voltage...but I'm too broke to buy one right now....so it will have to wait.
The final goal for me is a AC/DC tig welder.
Ash Small
Wed Oct 12 2011, 09:16PM
Daedronus wrote ...
Some are designed for total control of the welding current, including 'ramping up' and 'ramping down', etc.
I'll try to find some links (I have them somewhere). I'm also interested in uprating my SGTC based HF/buzz box AC/DC TIG welder to inverter technology so that I can run it from a small generator. (You can't run a buzz box from a small generator. Something to do with inductive loads and phase differences.)
Daedronus
Wed Oct 12 2011, 10:54PM
I really don't think current control/ramp is done at gate driver level.
There is probably a uC in there controlling a standard SMPS driver IC/adjusting the control loop, at least this is how I would do it.
Experimentonomen
Thu Oct 13 2011, 04:52AM
A welding inverter is nothing but a regular SMPS designed for high output current.
The only difference is that it is output current that controls the pwm duty cycle, on idle it sits at 50% for maximum output voltage to easily strike an arc, then once the arc is struck, the current control or rather limiting circuit kicks in and reduces the duty cycle to say 10% or less depending on the current the thing is set to, to maintain a somewhat steady current for welding.
This mode is called Current Control while the mode used in power supplies is Voltage Control.
It may look complex at first but its really simple once you understand the basics of how a smps works.
I think there are welding inverters that are just big buck converters as well.
