  • Guests: 36
10/21 ben106 (40)
10/22 803 (2025)
10/23 Iniaes (17)
Tektronix 2335 Not Working (Updated)
Corey
Fri Sept 30 2011, 01:01AM Print
Corey Registered Member #1902 Joined: Fri Jan 02 2009, 07:59PM
My scope stopped working earlier today. It stopped working when I switched it to Normal triggering, and I left it on for a few minutes. I was working on my project when I turned around and noticed that the intensity on the screen was way too high. Upon further inspection I realized that there was sporadic intensity when switching it to auto sweep and a high cycle setting. Bottom line is what can cause the in intensity of the beam to fluctuate and be generally brighter with very little control? Any tips or a service manual would be greatly appreciated. Thanks.
-Corey
Fri Sept 30 2011, 06:40AM
Bad heater drive?
-A
Corey
Fri Sept 30 2011, 06:10PM
I have found the filament leads, I will be testing operation later when I can get it back together. The suspected filament pins on the CRT read 13.1 Ohms. Is there a range of output I should be expecting from the drive? And is it safe to leave the CRT anode disconnected while powering it on, just want to make testing a little safer. Thanks for the help!
Edit: A problem may have been found. I've removed the ferrite transformer from the HV supply section to take measurements. There is a short from the suspected HV out winding, to one of the "low voltage" windings that connect to the PCB. The HV winding(two red wires leading into the multiplier) has a short of approx 95.7 Ohms to one of the primary coils. The real question is, is the short a failure, or it is it by design? Any insight before I start replacing things would be highly appreciated. Thank you for your time.
-Corey
