  • Guests: 62
Madgyver (40)
mike0t4ever (43)
Ken M. (40)
tesla500 (39)
Fabi (32)
hatto018 (40)
10/18 seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
Uses for superconducting wire?
Microwatt
Wed Sept 28 2011, 01:50PM Print
Microwatt Registered Member #3282 Joined: Wed Oct 06 2010, 05:01PM
lets say that somebody from the secret government gave you 100m of superconducting wire. thin as 28 gauge but can carry 100,000 amps. what would you build with it? how would you connect it to copper wire as to prevent the copper from melting?
Inducktion
Wed Sept 28 2011, 02:22PM
If it was superconducting....it could carry infinite amps. No matter how thick/thin it was.
I'd pprrrooobably try making some sort of lossless transformer. Or, maybe an induction heater coil. (since it has no losses, you wouldn't need water cooling anymore, plus it would be 100 times easier to maintain resonance)
Mattski
Wed Sept 28 2011, 03:13PM
Given that critical current densities max out out around 5kA/mm^2 (http://www.magnet.fsu.edu/magnettechnology/research/asc/documents/jeprog-100108-col.ppt) you wouldn't have to deal with 100kA in a 28AWG wire.
But hypothetically if you were pumping that much current through a copper wire you would probably want water cooling, and as large of a contact area as possible. If you have control over the superconductor portion you might even be able to get it formed into a large contact at the ends rather than a thin wire. Usually the copper portion doesn't need to handle that amount of current continuously which means you won't have as much heat to deal with, because once you start the current flow in the superconductor you can turn off the source.
Wed Sept 28 2011, 04:19PM
Mattski wrote ...
I agree with what you have said Mattski, but should he turn the superconductor into a loop(s) with the ends joined,Then through transformer action he can avoid constant driving losses? right?
PSCG
Wed Sept 28 2011, 04:32PM
PSCG Registered Member #3792 Joined: Sun Mar 27 2011, 06:07PM
I would try to built a coilgun....without any resistance in the coil, the projectile can reach 80 - 90% efficiency. Goodbye gunpowder!!!! smile
Mattski
Wed Sept 28 2011, 08:17PM
Patrick wrote ...
Mattski wrote ...
Yep, you could certainly start a current flowing in a superconductor loop through magnetic coupling. Another technique that can be used apparently is to create a superconducting loop, but leave a portion of it above the critical temperature. A current can then be injected into the loop around this portion that is resistive, and the resistive portion is then brought below critical temperature to allow the current to continue endlessly.
Microwatt
Wed Sept 28 2011, 09:52PM
i was thinking along the lines of a fist sized motor that can put out 200 horsepower. or howabout MHD thrusters for boats and spacecraft. even better would be portable high resolution MRI machines. with the ability to make megagauss fields many fields of science such as fusion
Wed Sept 28 2011, 10:09PM
Mattski wrote ...
....but leave a portion of it above the critical temperature. A current can then be injected into the loop around this portion that is resistive, and the resistive portion is then brought below critical temperature to allow the current to continue endlessly....
Oooo! thats the method he should use! thats easy and Garage/DIY implementable. the other methods...not so much.
PS for those of you who dont know, even with zero resistance, there is still a maximum current density for each semiconductor cross section.
radiotech
Thu Sept 29 2011, 10:25PM
How would you deal with the magnetic field produced by the 100,000 Amp wire?
If someone plucked it , what would cause it to stop vibrating?
haxor5354
Fri Sept 30 2011, 01:09AM
i'll make a super coil gun.
