  • Guests: 49
Madgyver (40)
mike0t4ever (43)
Ken M. (40)
tesla500 (39)
Fabi (32)
hatto018 (40)
10/18 seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
Broken ferrite transformer core
PSCG
Wed Sept 28 2011, 07:45AM Print
PSCG Registered Member #3792 Joined: Sun Mar 27 2011, 06:07PM
This morning i took apart a ferrite transformer that i removed from a ATX power supply. But after i dried it (i had left it overnight into an alcohol solution to remove the epoxy that keeps the I and E parts of the core) i noticed that it was broken in 3 places.
The question is : can i glue the ferrite core back or it will not work (i'm planning to use it as a Mazzili ZVS transformer)?
Daedronus
Wed Sept 28 2011, 08:16AM
It will work fine, it was after all glued in the first place, just that it was glued in 2 pieces.
PSCG
Wed Sept 28 2011, 09:07AM
Do i need a special type of glue (such as the one that was original used to glue the 2 pieces together) or any type of glue? As i imagine, it only needs to be strong enough to hold for a long time.
haxor5354
Wed Sept 28 2011, 12:28PM
super glue would do just fine
PSCG
Wed Sept 28 2011, 04:27PM
OK, i finally glued the ferrite core parts. Just perfect! Like new!
Thank you guys for the help.
