  • Guests: 35
Sanchez (36)
Knarvel (13)
10/17 mike0t4ever (43)
10/17 Ken M. (40)
Ferrite transformer power calculations?
Zum Beispiel
Sun Sept 25 2011, 11:19AM Print
Hello
I've recently come in to possession of four largeish ferrite E cores. The center leg of the core is 2.5cm x 2cm, or 5cm^2, the outer legs half that. Unfortunately the material is a mystery.
I'm pretty much a noob at SMPS design, but say if I wanted to use the cores for power transformers, what kind of power could they be ran at? Any ballpark figures?
An example of what I've had in mind was that I could wind some 2kV secondaries on them and run both center tapped for a nice +2kV,0,-2kV supply.
Mon Sept 26 2011, 04:49AM
Virtually all power ferrite transformers are MnZn type of fairly high relative permeability.
Yours is probably good for a few hundred watts.
Several inverters have been built by members here,
look at their designs and results first.
Daedronus
Mon Sept 26 2011, 10:14PM
I have seen E80 cores used in 2.2kW commercial SMPS, if that is of any help.
