  • Guests: 49
Sanchez (36)
Knarvel (13)
10/17 mike0t4ever (43)
10/17 Ken M. (40)
Puzzle electronics teacher gave us.
Tetris
Fri Sept 23 2011, 09:43PM Print
In the puzzle, we are given 4 lights, two DPDT switches, and a battery. We cannot use any other material except wires. Our job is to let any three bulbs be on at any given time, but the one that is off changes with each position of the switch. iE
POS 1 O X POS2 O O
O O O X
POS 3 O O POS4 X O
X O O O
I gave up on it because I couldn't figure it out. :P
Chip Fixes
Fri Sept 23 2011, 09:48PM
Well you can always connect everything to a breadboard and connect everything in different ways until it works :P
Tetris
Fri Sept 23 2011, 09:55PM
Camp Badger wrote ...
it isn't physical, its a program, but I tried that for about two full class periods, and at home I cannot find a good program or I only have one physical DPDT switch
Chip Fixes
Fri Sept 23 2011, 10:16PM
you can easily make your own dpdt switch with some wire and a few nails, here's a wiring schem: Link2
Coronafix
Fri Sept 23 2011, 10:17PM
It is similar to how a dpdt switch puts a DC motor into reverse.
There's a clue.
Fri Sept 23 2011, 10:21PM
Wouldnt a K-map help her resolve the logic needed to solve this?
Electra
Sat Sept 24 2011, 08:05PM
If you start by wiring one side of all the lamps to –ve, and all the switch commons to say +, Then you have 8 contacts from all the switches then you can parallel one contact from switch A with one contact from switch B, so that bulb 1 is on when SW A is off or SW B is off (actually in it’s other position) Bulb 2 is on when SWA is also off or SW B is on this time.
If you get all the connections paired up the right way their should be one condition that is not satisfied for a bulb to be lit for every combination of SW A and SW B, and you will have the sequence you want.
