  • Guests: 54
Barry (71)
Snowcat (38)
wylie (44)
02/01 Barry (71)
02/01 Snowcat (38)
02/01 wylie (44)
Speed of light 'broken' by scientists
Austin the Ozone
Thu Sept 22 2011, 09:22PM Print
Austin the Ozone Registered Member #3989 Joined: Thu Jul 07 2011, 05:10PM
http://www.telegraph.co.uk/science/science-news/8783011/Speed-of-light-broken-by-scientists.html
Turkey9
Thu Sept 22 2011, 09:30PM
I thought that special relativity stated that an object cannot be accelerated past the speed of light. Does it say anything about traveling faster? Weren't there particles proposed that can travel faster? I remember reading about them somewhere.
I'd also be curious to how they measured how long it took the neutrinos to get there if it was traveling faster than light. How was the instant it left synchronized with the end point?
Ash Small
Thu Sept 22 2011, 11:12PM
neutrinos are very strange things. It was believed that they don't interact with anything, yet they travel at different speeds depending on the medium they are travelling through. There are also loads of 'inconsistensies' with the 'standard model'.
(Or maybe the rumours were true, and the LHC is 'creating' a black hole, and even stranger phenomena. Heisenberg's paradox....Maybe, if it tries hard enough to find it, the LHC will actually 'create' the Higg's boson?)
EDIT: I've made a mistake here, in the first paragraph. See post lower down.
Forty
Fri Sept 23 2011, 04:20AM
yea turkey's got a good point.
how could they tell with such precision the neutrino's departure and arrival if they were going faster than any signal could be transmitted between the two points?
Ash Small
Fri Sept 23 2011, 08:03AM
Forty wrote ...
When I was at school in the '70s we measured the speed of light in the lab using rotating mirrors, and the results were surprisingly accurate.
It surprised me at the time.
Maybe, if their equipment will 'only' measure 'up tp the speed of light', maybe they've deduced that the neutrinos are travelling too fast for their equipment to measure?
Or maybe they can measure speeds in excess of the speed of light. Either way, the result is still the same.
Fri Sept 23 2011, 08:43AM
Interesting.
However, this would suggest that the effects from SN1987A would make sense.
Over such large distances assuming a 60 nsec delay for superluminal neutrinos they would be expected to arrive earlier than either the normal neutrinos or photons, an hour was mentioned.
If the difference is a consistent 60 nsec over distance n, then it should be possible to calculate precisely how far away a given supernova was.
Ought to be easy to test, look for a pair of neutrino spikes a short time apart and you can be pretty sure of a discovery.
-A
Adrenaline
Fri Sept 23 2011, 01:52PM
Adrenaline Registered Member #235 Joined: Wed Feb 22 2006, 04:59PM
Here is the document that outlines their results and the experimental design:
60ns * C ~ 18m
Their distance accuracy was 20cm
They calculated 6sigma significance for their timing errors...
It certainly is interesting.
Conundrum wrote ...
Interesting.
-A
I hope someone double checks my math but here goes...
According to this new data neutrinos travel at (730534.61m/(730534.61m/c - 60ns)) = 299799840m/s
Where as light is 299792458m/s, neutrinos are 0.002% faster.
SN1987A is ~186000 light years from earth.
The neutrinos should arrive 299792458/299799840 * 186000 = 185995.42 ~ 4.5 years sooner than light.
They only arrived a couple hours earlier, which should 'easily' be explained by light interacting with matter near the supernova and the neutrinos not interacting.
wolfman29
Fri Sept 23 2011, 04:55PM
wolfman29 Registered Member #4090 Joined: Fri Sept 09 2011, 04:43PM
Has anyone considered that there could be different "flavors" of neutrinos that travel at different speeds, some only arising in certain interactions? It could be possible that, yes, SN1987A was just normal light-particulate interaction that slowed down the light whereas the neutrinos just passed right through. However, if the SN did not create the interaction necessary for the superluminal neutrinos to be generated, then the concept is moot; nonetheless, they may still exist.
Ash Small
Fri Sept 23 2011, 05:38PM
I made a mistake in my first post in this thread. The last two posts jogged my memory.
I read a couple of years ago, regarding mutations from one flavour to another, that (I think I read this correctly) neutrinos have no mass, except when they are passing through another meduim. (I had posted that their velocity changed, depending on the medium, but it is the mass that changes. they are massless in a vacuum, if I remember correctly) but that otherwise they have no interaction with anything.) they can also change flavour.
(It's probably a couple of years since I read the article)
Tetris
Fri Sept 23 2011, 07:50PM
the link doesn't work for me.
