  • Guests: 46
M.A.D. (32)
12/14 M.A.D. (32)
12/15 marko666 (58)
12/16 Will T (16)
(Hack) Peak Atlas alternate power
Tue Sept 20 2011, 08:27PM Print
Hi all.
Just found this nice piece of hackery.
Seems that as I have a Peak Atlas CA which eats batteries, I am in need of a way to power it off something other than expensive 12V cells.
Plan so far is to purchase a new case, and put the CA PCB inside with a much larger phosphate cell and charger.
Adding a backlight would also seem a good idea, as the display is hard to see in low light.
Also add a 4 way switch so it can be set to LCR, CA, logic analyser or external HD44780 mode smile
Sound feasible?
-A
lightlinked
Wed Sept 21 2011, 06:04AM
lightlinked Registered Member #2087 Joined: Tue Apr 21 2009, 08:32AM
li-fe cells are only worth it if you have a big current draw. a li-po will be cheaper and flat with charging options more readily available.
Wed Sept 21 2011, 07:38PM
I have a chip that can charge up to a 150mAh LiPo, as well as numerous salvaged cells.
Interestingly they often use a charger chip in cheap MP3 players and digital picture frames so it might be feasible to recycle one in this way.
-A
Daedronus
Wed Sept 21 2011, 08:56PM
Why do they always use this oscillator set-up for LC meters?
I find this one
to be more reliable over a wider range or L and C
