  • Guests: 23
Ivan Kalafatic (17)
10/06 Ivan Kalafatic (17)
10/07 Pyromaniac (34)
10/07 Wavetuner (76)
How to step up .3 - .5 volts of electricity to 5 volts?
Inducktion
Sun Sept 18 2011, 07:42PM Print
How could this be possible? I have a small solar cell that puts out .5 volts in full sun, and .3 under slightly shady conditions. It's output current is 500 mA.
I tried a joule thief...but that didn't work. Any other ideas?
Sun Sept 18 2011, 08:05PM
For the 'Joule Thief' did you use a small toroid?
The transformer must saturate for a Joule thief to work.
There are several ics for this job under the general category of 'Energy harvesting' ... e.g. Link2
Dr. Slack
Sun Sept 18 2011, 09:47PM
The TPS61202 (see Sulaiman's link) can work down to 0.3v input with 5v output. It can't start up from 0.3v, it needs a higher voltage already on the output to bias the switch FETs, but if you're charging cells then you've got that anyway.
I did come across a better device (but of course can't find it now) that IIRC would work down to 30mV input, for stepping up Peltiers and themrocuple outputs. This used a FET bridge round the inputs to a step-up transformer, again it needed an existing several volts on the output to bias the FETs. Was it made by Linear Technology?
Pinky's Brain
Sun Sept 18 2011, 10:56PM
Yah you're right, Linear.
Might want to use slightly smaller ratio step-up transformers than in the datasheet to get a little safety margin on the input voltage.
Mon Sept 19 2011, 10:55AM
If you want a circuit that self-starts at 0.3V or less, try using a joule thief or similar circuit with a germanium transistor.
Pinky's Brain
Mon Sept 19 2011, 03:09PM
JFETs can be used for super low voltage oscillators as well.
Their on resistance isn't great, so it wouldn't be too good for efficiency ... but you could make an oscillator with 2 JFETs in series to create a bootstrap voltage for a plain old boost converter, after the output voltage is sufficient for the boost converter to run you pinch off the second JFET and stop the oscillator.
PS. I wouldn't be surprised if that is close to how the Linear IC works, start up with JFETs and then transition to MOSFETs.
testtest
Tue Sept 20 2011, 02:18AM
testtest Registered Member #3271 Joined: Mon Oct 04 2010, 02:29AM
I think Maxim may have chip for audio or cell phone or bluethoot that might do something like what you want.
