  • Guests: 32
Madgyver (40)
mike0t4ever (43)
Ken M. (40)
tesla500 (39)
Fabi (32)
hatto018 (40)
10/18 seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
Buck Boost Positive to Positive Voltage regulator?
Inducktion
Sun Sept 18 2011, 03:51AM Print
How can I use this as a positive to positive voltage buck-boost regulator? I'm trying to make a solar charger... but for some reason the designs in the datasheet are all for everything I basically don't need. :(
Sun Sept 18 2011, 06:48AM
For a positive supply to positive output with a single inductor you can have EITHER buck OR boost.
For buck/boost a transformer would be required.
e.g. flyback.
Dr. Slack
Sun Sept 18 2011, 06:55AM
You've picked a single switch, single inductor device, which can only invert polarity when doing a buck boost. You need both input *and* output switches with a single inductor for a non-inverting buck boost. With a transformer, any polarity can be chosen of course.
If you're connecting a solar panel and a battery, surely you can pick polarities to match the components you have to hand? Or have you already bolted them down to a common ground?
