  • Guests: 54
RoV IW3IPD (63)
01/13 si2030 (62)
DC from NST
M.A.D.
Sat Sept 17 2011, 04:54PM Print
M.A.D. Registered Member #4052 Joined: Thu Aug 11 2011, 04:43AM
Hello, I have a question. I know that some transformers can run of of pulsed DC. so what would happen if I ran 110V mains through a voltage doubler and then sent it into a NST as 220V pulsed DC? Would the NST output plused DC or would this just fry the transformer.
Ash Small
Sat Sept 17 2011, 05:11PM
I think, but I'm not certain....
Firstly, you,d need to input it in the form of a sine wave.
Secondly, the output would still be AC.
Thirdly, 110 mains AC goes from +110V tp -110V (difference between the two peaks =220V), so the output would be the same as it was before. (The doubler effectively just 'adds' the positive and negative cycles together)
I'm sure some-one will correct me about some of the above.....
Sat Sept 17 2011, 05:53PM
The NST would output a pulse in the instant you connect DC to the primary, then the core would saturate and the primary winding overheat shortly.
PS. You can use it as normal and rectify the output.
Sat Sept 17 2011, 05:56PM
Ash Small wrote ...
Thirdly, 110 mains AC goes from +110V tp -110V (difference between the two peaks =220V)....
According to American National Standard for Electric Power Systems and Equipment—Voltage Ratings (60 Hz) the RMS voltage in the USA is standardized at 120V with a permitted deviation range from 114 - 126V. In this regime, Vpk-pk min is 2√2*114 = 322.4V, and Vpk-pk max is 2√2*126V = 356.4V.
This aside, you would be better to rectify the output of the NST. You can use voltage doublers, triplers etc on the output of an NST, but the available current will be very low unless you use large, expensive capacitors, which I cannot recommend.
Take care charging any capacitors up to NST voltages!
Ash Small
Sat Sept 17 2011, 09:54PM
Proud Mary wrote ...
Thanks, PM. I overlooked the RMS. (The point I was making is that, assuming you manage to turn the output from the doubler into a sine wave, the output from the NST would be exactly the same (minus losses, of course), therefore it is a pointless excersise)
Sat Sept 17 2011, 10:49PM
Ash Small wrote ...
Well it wouldn't work as hoped, would it? smile
M.A.D.
Sun Sept 18 2011, 04:43AM
Thanks for the info, I am not planning to actualy do this, I just wondered if it would be a cheaper way to get high voltage DC. As capacitors and diodes rated for 220V are substantially cheaper than those rated for 10,000V.
