  • Guests: 68
RoV IW3IPD (63)
01/13 si2030 (62)
igbts in a mazilli fbt driver
Ben Solon
Mon Sept 05 2011, 08:42PM Print
hey, has anyone tried a mazilli driver with igbts? i have quite a few just laying around, and i don't really want to order mosfets. i have some 600v @ 60A (220 Icm) igbts just sitting there. the reason i ask, is because while they are insulated gate like mosfets, they switch like bipolars.
Dr. ISOTOP
Mon Sept 05 2011, 10:55PM
They'll be fine...for most power applications, FETs and IGBTs are both used as voltage-controlled switches.
anokata
Thu Sept 15 2011, 01:03PM
anokata Registered Member #1081 Joined: Sun Oct 28 2007, 08:04PM
I am use 18N120BND IGBT. It worked OK.
Kiwihvguy
Thu Sept 15 2011, 11:39PM
Kiwihvguy Registered Member #3395 Joined: Thu Nov 04 2010, 08:42AM
If some of the IGBTs don't have a didoe connected across the collector and emitter, do you have to put one there? If so, what type of diode?
anokata
Wed Sept 21 2011, 02:03PM
Diode no need for IGBT w/o diodes. If you wont - any super-fast recovery diode
Udiode=4Upower_supplay I>1Amper
Inducktion
Wed Sept 21 2011, 02:32PM
... I think what Anokata is trying to say, is that yes, you do need a diode from collector to emitter if you don't have one there already.
And, any 3 amp or higher diode will work fine, the faster the better. Generally try to keep the voltage rating of it around what the IGBT is rated at.
