  • Guests: 47
Autocad Drawings DWG converter to PDF & JPG
Tony Matt
Sun Jul 24 2011, 03:57PM Print
Tony Matt Registered Member #3700 Joined: Sat Feb 19 2011, 12:59PM
Hi !
I have some Autocad drawings to be inserted inthe Forum, but not all people have the Autocad program to open a drawing.DWG.
1- One solution may be convert the drawing made in autocat to the JPG format. Wath the program that may convert a drawing.DWG to drawing.JPG ? Were can I find it ?
2- The other solution may be convert the drawing made in autocat to the pdf format. Wath the program that may convert a drawing.DWG to drawing.PDF ? Were can I find it ?
or there are other easer solution to solve this problem ?
thanks
Newton
Sun Jul 24 2011, 04:28PM
You can use a screen capture programme like MWSnap3 to convert your .dwg on-screen image to a .jpg one using 'save as' if you can't find anything better.
Ash Small
Sun Jul 24 2011, 04:51PM
Proud Mary wrote ...
You can use a screen capture programme like MWSnap3 to convert your .dwg on-screen image to a .jpg one using 'save as' for want of something better.
I use 'Paint' (comes with Windows). Just use the 'Prt Sc' (Print Screen), (On most laptops you also have to press the 'fn' (function) button. Then use 'paste' command in Paint, save as a .jpg, then use 'image' 'flip/rotate' to trim off the unwanted bits using the blue dots at the left hand side and lower edge of the picture.
I would be interested in a program that converts .dwg or .tcw drawings to .jpg or .bmp, though.
(HINT: For those people who keep posting HUGE photo's (not mentioning any names, Grenadier wink ), this method can also be used to reduce them to a 'reasonable' size. (Open the .jpg in paint and use 'image' 'resize')
rp181
Sun Jul 24 2011, 09:41PM
AutoCAD itself should be able to. Export it as a jpeg, or take a screencap in AutoCAD.
Sun Jul 24 2011, 10:01PM
rp181 wrote ...
AutoCAD 2007 and up have the "export jpeg" feature i use it all the time, but i also use a screen cap program which works when i hit the "prt sc" button for other programs, and then i use Paint.net to mod the image resolution and pic size.
Tony Matt
Sun Jul 24 2011, 10:04PM
rp181 wrote ...
Thanks for your information.
However my autocad is ver 2000 and do not have the .JPG in the file export menu dow ,\
Any other suggestion ?
Thanks
Sun Jul 24 2011, 11:01PM
Tony Matt wrote ...
rp181 wrote ...
Thanks
Yes, AutoCAD 2000 lacks that feature so youll have mto get the view ports the way you want them, then use screen capture and a grpahic program to change from a .BMP to Jpeg or whatever. (I use Paint.NET)
rp181
Sun Jul 24 2011, 11:56PM
Don't use mspaint; it kills quality. Download GIMP and use that.
AleSeg
Mon Jul 25 2011, 12:14AM
AleSeg Registered Member #2727 Joined: Tue Mar 09 2010, 02:39PM
You can use DWG-trueView from AUTODESK to view and print DWG's. It's free.
Then you can install PDFCreator to get a virtual PDF printer (this time is more than free, is a GNU program) from which you can obtain beautiful PDF from your drawings printed from DWG-TrueView or ANY other program in your system.
You can install Ghostscript and GSview (both free) that can read PDF and extract from it the pages as JPG or what ever you want in high resolution .
see you
tobias
Tue Jul 26 2011, 11:01AM
tobias Registered Member #1956 Joined: Wed Feb 04 2009, 01:22PM
For good quality PDF drawings just install a PDF printer. I like the PrimoPDF.
Just make sure you use Prepress quality.
I think you can install a JPEG printer as well, but I never tried those.
