  • Guests: 40
Sanchez (36)
Knarvel (13)
10/17 mike0t4ever (43)
10/17 Ken M. (40)
bass guitar amplifier using mots and transmitting triode
Austin the Ozone
Sat Sept 17 2011, 02:10AM Print
Austin the Ozone Registered Member #3989 Joined: Thu Jul 07 2011, 05:10PM
I am trying to figure out if using a mot as a power transformer and another as an output transformer would work okay as a low frequency audio amplifier. I have never heard of anybody doing it but it seems like a neat way to build a high power bass rig. Any thoughts?
radiotech
Sat Sept 17 2011, 03:55AM
It probably would work with the secondary as the tube plate load and the mains winding to the speaker. Try it and see.
While experimenting,use a load bank of resistors on the primary (now secondary) to see voltage levels.
Mains transformers have been used to sub for output transformers and they do work.
Sat Sept 17 2011, 07:38AM
An MOT has a magnetic shunt which effectively adds a huge inductance in series with the winding, so if you do use an MOT as an output transformer remove the shunt.
(for most MOT the shunt is just a stack of laminations that are easily removed)
Sat Sept 17 2011, 12:51PM
And if you use a MOT as the output transformer, put an air gap in its core.
Note: The original mains winding will probably have a too high voltage output (and loading impedance), and might need rewinding.
Austin the Ozone
Sat Sept 24 2011, 08:04PM
Thanks alot for the replies! Is there any reason to leave the shunt in the power transformer or should I remove it too? One of transformers shunts came out easily, the other is glued in better.
A question I am having trouble finding an answer to, just for curiosity could tubes be strung together in series to increase the amount of voltage they can handle? People have done that with transistors according to http://www.diyaudio.com/forums/solid-state/91659-putting-transistors-series.html
Experimentonomen
Sun Sept 25 2011, 09:36AM
You mean like this? Link2
Boxed up: Link2
