  • Guests: 38
2N3055 driver fades
H8erade
Sat Sept 10 2011, 11:06PM Print
H8erade Registered Member #3451 Joined: Sun Nov 28 2010, 11:13PM
Hi everyone,
I recently build a standard 2N3055 flyback driver, such as the one shown on the Wiki.
If I leave the battery connected, the sparks eventually fade down to nothing. I have to disconnect it and wait for several minutes before I can see them again. What is causing this, and how can I fix it?
I think it may have something to do with the battery being drained, or the transistor itself. But neither seem to get very warm at all.
Ash Small
Sat Sept 10 2011, 11:44PM
More details please. What type of battery is it?
Sun Sept 11 2011, 12:11AM
Dry cells which are discharged too fast will quickly fail due to the build up of internal resistance. Such a battery can partially recover if it is allowed to rest for a while.
Remedy: use a battery with a larger capacity, and higher maximum discharge current rating.
Alex M
Sun Sept 11 2011, 07:17AM
Use a 12v lead acid battery. I encountered this problem when using alkaline battery's. I then got a 12V 7ah lead acid battery and it works much better.
