  • Guests: 43
Sanchez (36)
Knarvel (13)
10/17 mike0t4ever (43)
10/17 Ken M. (40)
Poly Note on Midi with Square Wave Output
MRacerxdl
Fri Sept 09 2011, 05:25PM Print
I have seen much Midi tesla Coils interrupters that make some kind of Polyphonic note at it.
I didnt understand how it works, Gregory uses an OR Operation between two notes signals, I didnt tried that, but I think for a DRSSTC this can be dangereous.
I'm using an FPGA so virtually I can do anything.
Any ideas for what can I do?
EDIT:
Saw some topics about Poly MIDI Interrupter, the only one that I see a concept is about uzzors2k interrupter:
But the mixed output is controlling voltage levels, that doesnt fit for my DRSSTC :/
The only problem that I see in OR-ing the notes is if I got a 300Hz note and a 600Hz note for example, only the 600Hz note will appear because the PWM oscillators are synced at same clock.
