  • Guests: 61
GTO SCR
PSCG
Thu Sept 08 2011, 09:20AM Print
PSCG Registered Member #3792 Joined: Sun Mar 27 2011, 06:07PM
I found this GTO type SCR. And if i'm correct, they can be turned off with a second trigger pulse and work like IGBT's.
I imagine that these SCR's would be perfect for coilgunning. What do you think?
2Spoons
Mon Sept 12 2011, 01:57AM
No, GTO's are turned off by sucking all of the anode current out through the gate. This isn't easy, and is why people have moved on to IGBT's and MOSFETs for inverters.
