  • Guests: 44
David (39)
12/25 Kolas (18)
12/26 buxtronix (50)
My first really big project (Plasma Speaker)
Chip Fixes
Sat Sept 03 2011, 03:21AM Print
As many of you know, I have been working on various designs of plasma speakers since early this year. I have finally found a design I really like. This is a work in progress and I will update this thread as time goes on.
I finished the modulation circuit: pics below, I apologize because some of them are blurry as I was in an awkward place to take pictures.
Complete set up: Link2
Outputs 1 and 2 from the TL494: Link2
Everything connected: Link2
Just the boards: Link2
I would like to personally thank Dr. Kilovolt, 2many, and Magnet18 for all the help they have given me. But of course, a big thanks to everyone who keeps this forum interesting and is willing to lend a hand
Sat Sept 03 2011, 04:58AM
Your pics are painfully blurry.
kiat
Sun Sept 04 2011, 01:09PM
kiat Registered Member #2115 Joined: Fri May 08 2009, 01:17PM
What's the output of the tl494 connected to? a flyback?
Chip Fixes
Sun Sept 04 2011, 04:50PM
In the picture they were connected to the Oscilloscope. When it's finished, each output will be connected to a Mosfet driver board which will be connected to a separate transformer, probably homemade so the transformers produce identical arcs.
Matt Edwards
Mon Sept 05 2011, 08:01AM
Matt Edwards Registered Member #2838 Joined: Fri Apr 30 2010, 07:55PM
Any progress since you posted your first photographs? I have always wanted to make a small plasma speaker but have never found a good circuit or flyback that I felt suitable. If you do end up winding your own HV transformers I would really like to see how it goes.
Inducktion
Mon Sept 05 2011, 04:38PM
Oidium45 wrote ...
Actually....you can use a 555 timer and some UCC2733x chips as drivers + a GDT for a plasma speaker. It works really well.
Chip Fixes
Mon Sept 05 2011, 05:51PM
Oidium45 wrote ...
I have started on the driver, I am using UCC37322 Mosfet drivers and a GDT like induktion said. I wouldn't use a 555 as I have found them unreliable at best and a TL494 is just as easy to use. I will update the post when the boards are done.
I have found a few suitable flybacks but the ones I have used in the past can't really handle anything above 18v and thus the arc size is limited to a very thin 3cm, I want an arc that's a bit longer and thicker; as a thin arc tends to move around a lot.
Tetris
Mon Sept 05 2011, 07:37PM
And I thought MY pictures and videos were blurry. Hm make a video of the arc when done! :D <3 audio modulation!
Chip Fixes
Mon Sept 05 2011, 07:49PM
Ah I will replace the blurry pictures in the next update. And yes there will be a video!
