  • Guests: 39
Madgyver (40)
mike0t4ever (43)
Ken M. (40)
tesla500 (39)
Fabi (32)
hatto018 (40)
10/18 seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
How to use FEMM 4.2, need help.
Wed Aug 31 2011, 02:53AM Print
Following up on my previous related thread here: Link2 i really need help figuring this out, Ive tried over the past 2 weeks to read the help file, but i just dont see how to get a useful result.
Im grateful to "2spoons" for his help, but i need a step-by-step click-by-click example on a file like this one, so i can see how its done.
]twocircles.zip[/file]
1314759217 2431 FT0 Twocircles
The larger outer circle would be the enviromental boundary, the left circle should be 14kv and right should be 0 volts, while the free space should be oil dielectric which is in the materials library. (in inches)
TY for any help.
EDIT: this pdf is helping, ill try again tomarrow morning. FEmm
]tutorial-electrostatic.pdf[/file]
Thu Sept 01 2011, 04:38AM
Ive gotten this far, but still dont really see how this program works.
1314851914 2431 FT123350 Tutorialfemm
1314854600 2431 FT1630 Tut2
It looks like this.
1314854600 2431 FT1630 Tutorial1
but should look like this.
2Spoons
Thu Sept 01 2011, 05:59AM
FEMM discussion group on yahoo : Link2
Thu Sept 01 2011, 06:13AM
Im trying to do some analysis on the field distrubution on the HV resistors seen below.
1314857610 2431 FT123350 Fileld Analyisis1
--On the left, the long resistors are 20kV, 75Mohm, which had the blue silicone removed via sandpaper. This resistor is thus destroyed.
--On the right, the shorter resistors are 14kV, 125Mohm, MEK was used to removed the silicone which came off so easily this resistor is probably still useable.
*Notice the bottom 0.2 inches are different, and would have a different field distrubution, presumably.
Mattski
Thu Sept 01 2011, 06:46AM
Looks like you've set the top right two line segments to 1V as well the two line segments they are facing. The "inner" two line segments should be 1V and the outer two should be 0V if you're following the tutorial. See below:
1314859577 1792 FT123350 Femm Sqr Cap
Thu Sept 01 2011, 06:54AM
Mattski wrote ...
Ooops! your right.
1314860307 2431 FT1630 Presto
Yay! (i changed the field from 0-1V to 0-1kV just to see what would happen)
TY, Mattski
jpsmith123
Thu Sept 01 2011, 02:34PM
Patrick I'm curious as to why you want to model these resistors? Is it just so you can learn how to do field simulations, or is there some other reason?
Thu Sept 01 2011, 06:32PM
jpsmith123 wrote ...
Reason: HV oscilloscope probes, high bandwidth.
Ive been thinking about Marco Denicolai's tesla coil + 600kV 10MhZ probe. Field analysis has proved to be important in desinging low capactance high bandwidth probes. (I think ive been following his work since 2000 or 2001 ?! WOW thats like about 10 years.)
At Link2 he gives a good explanation of the field arrrangement and step response vs time.
My current thinking has me wanting to simulate grading plates for field control, on the top and bottom of the resistor string.
1314922970 2431 FT1630 Pe
EDIT: Im going to presume that the funny greek symbol here (Epsilon sub X, and Epsilon sub Y), means dielectric constant or permitivity? I also assume some materials can show polarized field propagation? thus the different fields ?
Fri Sept 02 2011, 04:51AM
Woooo Hoooo! Ive got it figured out!
1314939090 2431 FT123350 First
Its about dam time.
Teal = 0 volts
Magenta = 14.5kV
Yellow = 7kV
1314945066 2431 FT1630 Platev
A well linearized field seen above.
1314945066 2431 FT1630 Platev2
Much thanks to 2Spoons!
Mattski
Fri Sept 02 2011, 06:47AM
wrote ...
Yep, it's relative dielectric constant. Materials which are anisotropic (as opposed to isotropic) can have a material property such as dielectric constant which depends on the direction in which the field is applied. I'm not aware of common dielectrics which exhibit dielectric anisotropy though, generally you need to have a crystal for anisotropy.
