  • Guests: 56
2N3055 not suitable for High Frequency?
H8erade
Tue Aug 23 2011, 06:13PM Print
H8erade Registered Member #3451 Joined: Sun Nov 28 2010, 11:13PM
The 2N3055 page at RadioShack (Link2 has a few reviews which seem to be saying that this transistor doesn't work very well for HF flyback drivers. If this is the case, then why is the 2N3055 recommended for this purpose on HvWiki and PowerLabs? I understand that that the single transistor driver is relatively low power, but is there a better alternative?
Ash Small
Tue Aug 23 2011, 08:08PM
There are plenty of better alternatives.
Most 2N3055's are recommended for up to 2.5-3MHz, but realistically are limited to around 1MHz.
In my opinion they are fine for in excess of 20kHz, (100kHz should be ok too). They were extensively used as power amplifiers in audio amplifiers so have good response over the audible frequency.
Bjørn
Tue Aug 23 2011, 08:30PM
Here it is mentioned that it is not a good choice Link2
Dr. ISOTOP
Wed Aug 24 2011, 12:34AM
smcerm wrote ...
Because the 2N3055 is a "classic" power transistor.
It has a horrible package and poor ratings. I'd suggest a Royer-based driver.
Wed Aug 24 2011, 01:41AM
Two words. Gain, and BJT. BJTs are lossy if driven without proper voltage/bias, as at least some are meant for linear devices like regulators or linear amps.
It is also low gain, so it takes alot of power to turn it on hard enough to prevent it from dissipating much heat.
H8erade
Mon Sept 05 2011, 05:42PM
Hm, thanks.
Can a power MOSFET be used in place of the 2n3055?
Ash Small
Mon Sept 05 2011, 07:00PM
smcerm wrote ...
Hm, thanks.
The circuit becomes a bit more complicated. Most people use a 555 or TL494 to drive the gate, I think. There are a few simple designs on here and on other websites. I can't remember offhand who's though.
