  • Guests: 32
using a fridge compressor vacuum pump to make a vacuum tube?
alf
Wed Aug 31 2011, 12:10PM Print
alf Registered Member #3925 Joined: Fri Jun 03 2011, 10:50AM
hey,
i am gonna use a compressor from a fridge, as a vacuum pump, ive not tried it,
but it seems Link2 it can pull a vacuum of 27 in. Hg.
would that be good enough to make a (crappy) crt or vacuum tube?
thanks. Alf.
cedric
Wed Aug 31 2011, 12:50PM
cedric Registered Member #2941 Joined: Fri Jun 25 2010, 08:08AM
Two of those pump in series are some time enough for some type of gas laser (cvl /Carbone dioxide ),it might work for a demonstration CRT,but for a vacuum tube I doubt..
Wed Aug 31 2011, 01:33PM
There are illustrated instructions for converting a fridge pump into a vacuum pump in Stong CL The Scientific American Book of Projects for the Amateur Scientist New York 1960.
The fridge pump is intended to be used together with a mercury diffusion pump, whose construction is also described in a practical way for the home constructor.
The two pumps pulling in series are used to evacuate a linear accelerator powered by a Van der Graaf Machine, also described with drawings.
Forty
Wed Aug 31 2011, 08:30PM
i might try the same but with a dehumidifier pump.
Thu Sept 01 2011, 12:25AM
If you Google glow discharge and Grimm glow discharge you will find many fascinating experiments that can be performed at the pressures attainable by your fridge pump, mostly needing only a few hundred to a few thousand volts to get into the business.
cedric
Thu Sept 01 2011, 11:02AM
I have to apologies for my previous post, I have seen some one making a triode at atmospheric pressure with in a candle flame, I assume the flame is needed to assure enough atom of the gas are ionized to guaranty some electric conduction and those pump can reach a vacuum where gas is easy to ionize ,so it might be that demonstrating a triode is possible even with fairly low vacuum....
here is the link: http://www.youtube.com/watch?v=-aAwyUoawkc
Thu Sept 01 2011, 11:34AM
Don't forget there are gas triodes - but they perform rather differently to the high vacuum type. The thyratron is one example.
Your fridge pump will also easily reach the pressure needed to make your own Geiger-Müller (GM) tubes.
Adam Munich
Thu Sept 01 2011, 05:04PM
I'm pretty sure that a compressor from an AC unit + a mercury diffusion pump is they way to go if you don't feel like buying a 2 stage vacuum pump.
Thu Sept 01 2011, 05:16PM
Grenadier wrote ...
I don't think anyone nowadays would choose a mercury diffusion pump, Adam, because of the toxicity hazard. Diff pump oils are costly, but will last a long time if you take
care of them.
The Javac A/C pump is popular with UK enthusiasts, is relatively inexpensive, and claims a lowest pressure of 25 microns. Link2
But a fridge pump is a very good place to start on modest means, and can produce a pressure low enough to observe all sorts of very interesting phenomena - more so than high vacuum in many respects.
Ash Small
Thu Sept 01 2011, 05:23PM
Grenadier wrote ...
An oil diff. pump around 2" in diameter is probably what you want, maybe 1" diameter.
