  • Guests: 57
Madgyver (40)
mike0t4ever (43)
Ken M. (40)
tesla500 (39)
Fabi (32)
hatto018 (40)
10/17 mike0t4ever (43)
10/17 Ken M. (40)
Coffee Timer
cduma
Tue Aug 23 2011, 11:29AM Print
Im not sure what the limitations are for the 555/556 but, I want to use a 556 timer to flip a relay after 7 hours and 50 minutes and then have the other half of the timer turn it back off. Is this within the capabilities of the 556?
Dr. Slack
Tue Aug 23 2011, 12:41PM
No, a time constant that long is essentially impractical. A big R is going to be challanged by board leakage, a big C will be too costly or too leaky, depending on technology.
The 4040/4060 type CMOS ICs have been built for this sort of application, with 12/14 bit counters in them to reduce the RC time constant needed when making long delays.
cduma
Tue Aug 23 2011, 03:45PM
Im not too familier with those. Could you point me towards a schematic for a similar application?
Dr. Slack
Tue Aug 23 2011, 06:49PM
Google "4060 timer" works for me ...
radiotech
Tue Aug 23 2011, 11:41PM
What relay are going to use and how are you interfacing it with your coffee maker?
Forty
Wed Aug 24 2011, 12:48AM
you could pick up one of these guys:
it takes up about a 2"x2"x2" cube.
cduma
Wed Aug 24 2011, 11:20AM
Doh'! I tried a couple other search terms...
Thanks forty, I may try that in the future but, I wont learn anything if I take that route
