  • Guests: 20
  • Most ever online: 441
    Guests: 441, Members: 0 on 01 Oct : 16:32
TwirlyWhirly555 (33)
10/04 Michael W. (36)
10/05 GhostlyFigures (36)
10/06 Ivan Kalafatic (17)
Printing Circuit Boards
Chip Fixes
Tue Aug 23 2011, 05:43AM Print
Well I was going to write a whole post on how cool it would be to print with conductive ink, but alas! I'ts already been done Link2 :(
So I guess I still have some questions. I have an old working printer in the garage and I was wondering if it's possible to widen the gap between the rollers so you can fit a PCB board through it.
However, I think it would be cool to be able to print traces on a pcb with a home printer, either by using some stiff paper-like-material or just using paper and then gluing it to a pcb. This would only be viable for low current low voltage applications though.
Also, also does anyone know where to buy conductive ink in quantity?
Feel free to add your ideas about printing with conductive ink, and my printer is ready to go for experimentation if need be
Dr. Slack
Tue Aug 23 2011, 12:44PM
What would be cool is to ink-jet electroless copper onto bare PCB (the stuff that makes the inside of via holes conductive when making plated thru boards) and then plate up with copper to a workable thickness. I wonder how well it adheres to bare PCB?
Ash Small
Tue Aug 23 2011, 02:34PM
Dr. Slack wrote ...
Conductive paint is used for electroplating plastic.
Nickel is often built up this way for things like moulds for plastic toys/ models, etc.
Whether you could plate copper directly onto conductive paint/ink or whether you'd need a 'Woods strike' (flash nickel plating) first is something I'm not sure about.
Tue Aug 23 2011, 03:25PM
I don't think the viscosity of most conductive ink would allow for a typical printer cartridge to eject it properly. I think someone said that here on a previous thread about conductive ink, and it seems to make sense.
Chip Fixes
Tue Aug 23 2011, 04:19PM
Arcstarter wrote ...
hmm, well if I find some conductive ink for cheap I will test it out
Pinky's Brain
Wed Aug 24 2011, 03:36PM
Your link shows ink being used to catalyse electrodeless plating. Another method is flash sintering of nano powders deposited with solvents.
Untreated conductive ink with low enough viscosity to be jettable has too much resistance for most circuits.
Wed Aug 24 2011, 06:44PM
Has anyone experimented with DIY conductive polymers in a solvent, such as polyacetylene?
-A
Forty
Wed Aug 24 2011, 09:27PM
has anyone tested to see if the silver sharpie marker, or the silver oil based paint sharpie pen are conductive?
Thu Aug 25 2011, 12:10AM
the Maker-Bot and rep rap are trying to include wire in the normal objects being made while still in process, if they can make such a wild idea work, then we all be free of acid, pens and all the rest of it!
I think as far as real printing possiblity by home/hobby/DIY, types might need to investigate using a thin conductive gel epoxy extruded (though a tiny needle) on to a plate or plastic, via pen plotter type cnc machine.
As has been said, inkjet and circuit pen markers just dont seem to work in thin layers due to the limits of current chemistry, also the circiut printing is only part of the problem, you have to be able to--after the board is"printed" be able to place your SMT/IMT components on the board then attatch via the same conductive epoxy or something. Even the circuit repair pens, which are silver, that advertise " maybe solderable" hasent prooved to be true in my experience.
Adam Munich
Thu Sept 01 2011, 04:36PM
How about printing directly on copper clad, followed by a standard etch?
