  • Guests: 56
Resistors in the Marx generator
franek19
Sun Aug 21 2011, 06:03PM Print
franek19 Registered Member #3265 Joined: Sat Oct 02 2010, 08:30AM
Hello I did generatopr Marx but I have a problem with resistors. I use Russian mlt and I pierces after they surface, they tried to insulate the hot glue but Not helping anything. It supplies 40 kV
Adam Munich
Tue Aug 23 2011, 11:28AM
If I understand you correctly, your resistors are sparking over.
Solution, use a few resistors in series.
franek19
Tue Aug 23 2011, 01:59PM
I used two resistors 2W
Myke
Tue Aug 23 2011, 03:16PM
So then use more 2W resistors in series smile
2W resistors really aren't made for those kinds of voltages anyways so there is no surprise if they arc over. You could also use a lower input voltage to avoid needing so many series resistors but that lowers your total output voltage (unless you add more stages to compensate) and you would need to change the gap distances.
Tue Aug 23 2011, 03:22PM
You could also put the resistors in oil, or pot them in paraffin wax, or epoxy. However the proper way is to just use more/different resistors. My 200kohm resistors rated for i believe 5w are only made for 11kv, so it makes sense.
franek19
Wed Aug 24 2011, 07:32AM
I gritted my shirt shrinkable resistors and is well.
Thank you for your help
teravolt
Wed Aug 24 2011, 01:44PM
you might be able to use indutors to. I made a doreknob marx with 1M 2w X 2 resistors with no problem. you could use table salt or copper sulfate solution in small tygon tubing for resistors. also vishay also maks a high voltage rsistor series that is a 2w 10kv type. I bought mine at newark. what sort of suplies do you have on hand
