  • Guests: 41
davovinch (75)
Duncan (37)
Vatorius (60)
waicool20 (27)
12/11 Forty (38)
12/13 williamn (48)
12/13 ReddyK (57)
Homemade geiger-muller tube using film canister
hsieh
Sat Aug 20 2011, 03:27AM Print
hsieh Registered Member #1412 Joined: Thu Mar 27 2008, 04:07PM
I found some websites and videos about making geiger-muller tube using film canister or other ordinary plastic container.
Link2 (construction start at 1:40)
I cannot read japanese.Can someone explain these further?
other related video:
Thanks
Adam Munich
Sat Aug 20 2011, 04:17AM
Well unless you pull a vacuum and backfill the can with neon, it ain't gonna work! Link2
That's just another one of those "make mountain dew glow" videos.
Sat Aug 20 2011, 09:25AM
This strikes me as a primitive spark detector - the darling of 1970s particle physics. See how the alphas really get it going, and how the detector events create EMI, as sparks do.
It is wrong to call it a GM tube, because it is not a gas amplification device working in the Geiger-Müller region.
hsieh
Sat Aug 20 2011, 11:46AM
Grenadier wrote ...
The video says fill the canister with butane.Will this work?
Bored Chemist
Sat Aug 20 2011, 12:30PM
They may think they are filling it with butane, but they are sadly mistaken. You can't pour a gas into a can and hope it stays there while you stick some plastic over the thing.
Sat Aug 20 2011, 02:24PM
hsieh wrote ...
Grenadier wrote ...
Helium butane mixtures had a brief vogue as a GM counting gas in the 1960s, and both butane and propane have been used in proportional counting, usually mixed with a Noble gas.
I didn't notice the detail about the fill gas, Adam, until I read your post.
Hydrocarbons, often ethanol, were used as quench gas in first generation GM tubes, which typically operated at 1.2 kV or so, and had a limited life span until the quench gas was used up. The introduction of halogen quench agents - usually Br - reduced the operating voltage to ~350V - 600V in second generation GM tubes, which also had a longer operating life. Most readily available tubes are of this second type.
hsieh
Sat Aug 20 2011, 05:26PM
So, is this worth further experimenting?
I cannot find geiger tubes here in Taiwan and cannot buy it on ebay because I don't have a credit card.
Adam Munich
Sat Aug 20 2011, 05:41PM
I wouldn't waste your time on this.
As for finding a tube, I wonder if you could send LND an international money order. Get a mica window tube; although it is more expensive it is far more useful. Link2
