  • Guests: 45
Sanchez (36)
Knarvel (13)
10/17 mike0t4ever (43)
10/17 Ken M. (40)
Detailed paper on production of high energy X-rays by scotch tape
Nah
Fri Aug 19 2011, 07:59PM Print
Nah Registered Member #3567 Joined: Mon Jan 03 2011, 10:49PM
Hello!
I am looking for a paper on the said topic that has detailed numbers, charts, and figures on how the researchers built the device, speeds of tape, x-rays emitted, etc. I am not looking for a paper with complicated advanced math. A paper that explains how they did it, and clear data would be good. I am trying to build one for myself and perhaps experiment on the basic idea.
This is the best example I could find, but it doesn't have much data on building details or theory. I am pleased that it used english for most of the data, and not obscure theories that a well read hobbiest would not know.
Thank you
Paul
Adam Munich
Sat Aug 20 2011, 04:10AM
I'm pretty sure they just pulled a vacuum and unwrapped some tape smile
Tetris
Sun Aug 21 2011, 07:20PM
X-Rays from scotch tape? Wow!
Mon Aug 22 2011, 07:33PM
I've read the paper by UCLA guys in 2008. Their vacuum level was 1 micron.
But I attest that the demonstration is very tolerant of variations in speed and vacuum.
33 microns is enough vacuum to get x-rays easily detectable by Geiger counter outside a plastic bell jar.
In that experiment, the free end of Scotch tape was started on the shaft of a DC gearhead motor inside the vacuum.
Tue Aug 23 2011, 01:24AM
I have seen a video of this phenomenon being experimented with by what i believe was some university. Apparently they used 150 microns, and there was plenty of radiation to be observed through a thick bell jar by a geiger counter.
I am pretty amazed that triboluminescence can be used to make x-rays that can take such a clear x-ray photograph. A very cool phenomenon. I wonder if it will ever be utilized for a practical device.
cedric
Tue Aug 23 2011, 09:26AM
cedric Registered Member #2941 Joined: Fri Jun 25 2010, 08:08AM
I bet a Van de Graaff generator in vacuum would work just as good...
Adam Munich
Tue Aug 23 2011, 11:46AM
If I understand that paper correctly;
The vacuum is needed for dielectric insulation.
The tape can be rewound and reused.
It makes plenty of x-rays, including high energy ones.
It can take radiographs.
So we have a relatively high intensity xray generator that can be reused... and run off a D battery.
Need I say this is awesome?
cedric
Wed Aug 24 2011, 11:57AM
it's funny to think that astronaut are gonna need to reevaluate the benefice of using tape in space...
Nah
Thu Aug 25 2011, 02:41PM
Hi!
From what I've read, 150 micron is the hoghest preasure that has been used for the scotch tape idea. I also know that the x-rays are emited in peaks. What I would want is to see if the 150 micron outputed less x-rays than the 1 micron. It would be expected right? Also, does the speed of the tape affect production?
If I had a simple graph from each of the said experements, we could easily see if it is a factor. Also, I was thinking of using a glass canning jar instead. Does anyone know the max vacuum they can stand?
Paul
Ash Small
Thu Aug 25 2011, 03:06PM
Nah wrote ...
., I was thinking of using a glass canning jar instead. Does anyone know the max vacuum they can stand?
Paul
When using glass vacuum vessels, ALWAYS use additional shielding.
