  • Guests: 45
Sanchez (36)
Knarvel (13)
10/17 mike0t4ever (43)
10/17 Ken M. (40)
Dead time IGBT bridge
Fri Aug 19 2011, 09:34AM Print
Hi,
when designing the minimum deadtime in an IGBT bridge, do I consider just the turn-off delay time for the off part or should I calculate with tdoff + fall time? From IGBT data sheets I have seen, the "fall time" is really just a current fall time after the voltage has commutated, so the other transistor can switch after the first one's turn off delay time right? I hope it's understandable.
