  • Guests: 49
Can You Help Me?
Osama Ma'mon
Thu Aug 18 2011, 02:56PM Print
Osama Ma'mon Registered Member #3144 Joined: Fri Aug 27 2010, 01:44PM
Hi All
i nead help to make 4 mhz Oscillator but i nead it to drive 2 (60 amps igbt) without GDT
Hope You help me .
Thank you.
Thu Aug 18 2011, 03:29PM
wait what igbts can run at that kind of frequency? didnt know that :O
cedric
Thu Aug 18 2011, 04:06PM
cedric Registered Member #2941 Joined: Fri Jun 25 2010, 08:08AM
Osama Ma'mon wrote ...
Hi All
Hope You help me .
Thank you.
same here, 4 Mhz (or mhz?) you need rf mosfet for the job, for the rest a royer oscillator might bring you there (I try with normal mosfet and never could go above 1 Mhz but it's also a problem to start the oscillation.
Osama Ma'mon
Thu Aug 18 2011, 06:33PM
Tom Williamson wrote ...
sorry about that
but i want 4 Mhz Switching
Dr. ISOTOP
Thu Aug 18 2011, 07:43PM
sorry about that
Well, you're not going to get those kinds of frequencies with anything except RF FETs, unless you Class-E it.
Osama Ma'mon
Thu Aug 18 2011, 08:05PM
bwang wrote ...
sorry about that
ok i want a circuit can drive 2 rf mosfets in 4 Mhz
Thu Aug 18 2011, 08:21PM
A gate driver in TO-220 (TC4452) on a heatsink should do the job, or more of them in parallel. You can also try a "totem pole" of NPN and PNP fast bipolar transistors which can swith half an amp or so, driving a half bridge of small, low gate charge P and N FETs.
Fri Aug 19 2011, 02:12AM
IRF510 are cheap and will work to about 20 MHz
for more power you will need proper rf fets and good design/layout.
Unless you have experience at this power/frequency level you should consider a commercial/ready made rf PA.
There are lots of 27 MHz high power PAs on eBay for example. (CB 'burners')
Osama Ma'mon
Fri Aug 19 2011, 05:15PM
what is the part number of the power mosfet like IRF510 (Same frequancy 20 MHZ) in IRFP*** or any power mosfet
