  • Guests: 58
01/13 si2030 (62)
problem drawing arc from single MOT?
LD LANGER
Fri Aug 19 2011, 01:54AM Print
LD LANGER Registered Member #3824 Joined: Sun Apr 10 2011, 08:29PM
Hi, I'm having trouble drawing arcs from a single MOT. Phasing is obviously not the issue, and I have checked the secondary with a voltmeter and at about 35V input I get 200V out. ?? Whats going on here?
Thanks
Forty
Fri Aug 19 2011, 02:03AM
have you tried running it straight off of mains?
LD LANGER
Fri Aug 19 2011, 02:05AM
yeah its on a variac so I've pumped it up to 120V quite a few times now and cant draw more than a really crappily made flyback. I have another MOT primary in series because when I connected it without a ballast it blew my 20A fuse??
This is ridiculous.
Forty
Fri Aug 19 2011, 02:59AM
maybe you have a short in the primary of the first one. try hooking up the second mot and see if it works better.
mnr
Fri Aug 19 2011, 03:16AM
mnr Registered Member #996 Joined: Sun Sept 09 2007, 06:17PM
LD LANGER wrote ...
This is ridiculous.
Is the secondary of the MOT you are using for a ballast shorted? If not your power throughput will be seriously limited.
LD LANGER
Fri Aug 19 2011, 01:26PM
mnr wrote ...
LD LANGER wrote ...
This is ridiculous.
Yes, I left the secondary OC. That is where the problem most likely lies. Just how does the power throughput increase with a shorted secondary? Does the transformer saturate when the secondary is SC allowing higher current through?
Thanks a lot
mnr
Fri Aug 19 2011, 08:02PM
LD LANGER wrote ...
Thanks a lot
When the secondary is open circuited only the magnetizing reactance is providing a current path. When the secondary is short circuited, you will be limiting the current with the leakage reactance, which is much lower than the magnetizing reactance.
http://ece.mst.edu/documents/class_exp/ee_209labs/Experiment_5_Single-Phase_Transformers.pdf has a decent description in the first four pages.
cduma
Sat Aug 20 2011, 03:35PM
It sounds like a short on the primary to me. I have drawn unballasted arcs from a MOT without blowing a 15A fuse.
