  • Guests: 41
Kolas (18)
Dillon4DynamicHarmonics (41)
12/25 Kolas (18)
12/26 buxtronix (50)
Is there anything I should know about putting two DC Powersupplied in Parallel?
aarpcard
Wed Aug 17 2011, 06:37PM Print
aarpcard Registered Member #2848 Joined: Tue May 04 2010, 05:19AM
I've made a custom flyback+driver with which to power my coil gun. I have two 15v, 6.3amp laptop power supplies. I want to use both of them in parallel to power the flyback so I can draw more current. I am currently using 1 of them. Is there anything special I should do to connect these in parallel? Should I put diodes in series with each power supply to prevent current backwash into each PSU?
Forty
Wed Aug 17 2011, 06:55PM
diodes on the + and gnd should work to effectively isolate them from each other. search "paralleling psu's" on here, I believe there was a discussion about it for powering a subwoofer.
aarpcard
Wed Aug 17 2011, 06:59PM
Thanks I'll search for that topic. Quick question though, - should I put diodes on the + and ground of Each PSU, or the + and ground of only 1 of them.
I'm thinking it should be both PSU's, am I right?
aarpcard
Thu Aug 18 2011, 02:49AM
I'm trying to find a few schottky diodes that would work with this. Would something like the following work?
Unless I'm missing something everything looks fine.
