  • Guests: 58
Sanchez (36)
Knarvel (13)
10/17 mike0t4ever (43)
10/17 Ken M. (40)
Solid state power supply buzzing
ZakWolf
Tue Aug 16 2011, 09:52PM Print
I pulled an 18v 25watt ssps out of an old printer, I wanted to use it to power my plasma speaker which would draw more then 25 watts. I hooked everything up and switched on the power, the power supply took a second to turn on, but when it did an arc started. I let it run for a sec turned everything off and did a heat check, nothing was hot so i fired it up and drew about 1 1/2 long arc with now problems. My question is the power supply makes a buzzing sound when under a load , and the sound gets louder as i draw out the arc. Is there any way to make the buzz quieter or stop it all together?
1313531535 3114 FT0 031
Tue Aug 16 2011, 10:04PM
you might be destabilizing the control loop, causing unstable oscillations being reported to the power switch and transformer, thus the buzzing.
Not sure what you can do about it though, control loops can be sensitive and if you change them you can torch the whole thing.
ZakWolf
Tue Aug 16 2011, 10:21PM
I was looking at the on board filter cap. its only rated at 68uf at 400v, if i switched it out for more capacitance would it help? This is just an ASSumption but wouldn't unstable oscillations cause a considerable amount of heat.
P.S the arc is silent
Tue Aug 16 2011, 10:41PM
SublimeVolts wrote ...
Ive had this problem with stepper motor PS's, you can try to add more capacitence at the load end.
ZakWolf
Tue Aug 16 2011, 10:48PM
what do you mean the load end I have a 10,000uf cap to filter the output, im talking the cap that filters the rectified dc on the board.
Edit: I replaced the cap which did nothing, so i guess is will put it in a sealed box. thanks for the help
