  • Guests: 27
Sanchez (36)
Knarvel (13)
10/17 mike0t4ever (43)
10/17 Ken M. (40)
Differences between good fiberglass, and good Carbon fiber.
1 2 3 4
Tue Aug 16 2011, 07:07PM Print
Does anyone know the differences between good well-made fiberglass and the good well-made carbon fiber? Are these fractional differences noticable/worth-it at our small 18 inch) UAV scale? I know carbon fiber is superior at the large scale as in manned air and space craft.
I want to keep the cost and difficulty down while still coming close to what carbon fiber would be. I've done fiberglass before, but not to much of the carbon fiber.
TY,
Ash Small
Tue Aug 16 2011, 07:14PM
If you are having to ask these questions, you will be better off using glass fibre.
You'll probably want 'S' type woven glass (woven rovings)
You need to know exactly what you are doing in order to take advantage of the properties of carbon.
I assume you'll be using a wet lay-up, with epoxy, rather than pre-preg, but you will probably still benefit from vacuum bagging if you have access to a pump.
What is this for?
Tue Aug 16 2011, 09:02PM
Ash Small wrote ...
I was afraid someone was going to say that.
Ash Small wrote ...
like this pic:
1313529189 2431 FT1630 Fgpic
Ash Small wrote ...
elaborate please...
Ash Small wrote ...
Yes as I make mostly flat sheet or compression molding for fiber glass.
Ash Small wrote ...
What is this for?
Go here -> Link2 , youll see.
Ash Small
Tue Aug 16 2011, 09:08PM
Patrick wrote ...
Ash Small wrote ...
elaborate please...
Ash Small wrote ...
What is this for?
I'll elaborate later, for now I'd suggest using glass, with a view to maybe 'moving to carbon' once you've got everything else (electronics, etc) sorted out.
(EDIT: Carbon won't neccesarily make it any lighter, but, if done properly, may make it stronger)
Tue Aug 16 2011, 09:15PM
Ok that sounds good , pic posted above.
Ash Small
Tue Aug 16 2011, 09:29PM
Patrick wrote ...
You're on the right lines there, maybe a finer weave/lighter cloth....but get the method 'sorted' using glass before moving to carbon. (Just my 2 cent's worth)
Tue Aug 16 2011, 09:39PM
Can you give me an american source to buy this kind of stuff, i mostly buy Tap plastics and automotive FG stuff.
Ash Small
Tue Aug 16 2011, 10:10PM
Patrick wrote ...
I'll look into it tomorrow (I've had a drink or three now), but West Resins might be a good starting point for a google search (I know they do resins, not re-inforcements, but it still might be a good starting point).
Tue Aug 16 2011, 10:43PM
Ash Small wrote ...
Patrick wrote ...
TY.
2Spoons
Tue Aug 16 2011, 11:14PM
I bought some carbon/kevlar tube for my kayak paddle from here Link2
They've got all sorts : glass, carbon , kevlar, basalt, and mixed materials. In cloth, tube, etc.
