  • Guests: 53
Sanchez (36)
Knarvel (13)
10/17 mike0t4ever (43)
10/17 Ken M. (40)
Vacuum Powered Dryer
cduma
Mon Aug 15 2011, 07:53PM Print
One of the unpleasant things about being a scuba diver is getting into a cold wet wetsuit. You cant put them into a clothes dryer because they are very heavy and would melt. My idea is to place them into a vacuum chamber with a standard ball valve to regulate pressure and have a car air conditioner compresser draw the vacuum. Would this be practical?
Ash Small
Mon Aug 15 2011, 08:32PM
I'd suggest just blowing air through it.
If you do use a vacuum pump you'll need a purge valve (I think that's what it's called) to allow air into the system between the chamber and pump, to flush water out of the pump (I think).
cduma
Tue Sept 20 2011, 04:13PM
Blowing air through wont work. The neoprene is very think and the water would need to flow to the surface for the fan to work. If The pressure was lowered then that should cause the water to evaporate.
Mattski
Tue Sept 20 2011, 04:24PM
I think Ash is suggesting to blow air through the inside of the suit, not through the material. Some products do exist which are designed for this: Link2
Bored Chemist
Tue Sept 20 2011, 06:23PM
It won't work very well
The water needs heat to evaporate and a neoprene wetsuit in a vacuum chamber is a very good thermal insulator.
You could try a vacuum desiccator which relies on having a drying agent in the chamber.
Turkey9
Wed Sept 21 2011, 02:44AM
Bored Chemist wrote ...
The point of putting it into the vacuum chamber is to lower the boiling point of water to a temperature below room temperature.
I bet it would work great as long as you can find a chamber large enough to fit it in. The pump would be the weak point. The lower the pressure the faster the water will evaporate. The pump will need to have enough throughput that it can pump out all of the water vapor as it forms.
Wed Sept 21 2011, 06:37AM
Yea the pump would be the weak point, but you can dramatically decrease the vacuum needed for the water to boil by adding *some* heat. I have no idea what kind of vacuum you could expect out of a car A/C pump, but a pump that can pull a vacuum around 700 torr, water will evaporate at 100 degrees F. Link2
Bored Chemist
Wed Sept 21 2011, 06:29PM
This "The lower the pressure the faster the water will evaporate." simply isn't true.
What happens is that the water boils, in doing so it extracts energy from itself and the surroundings and it cools. After a while it freezes. Ice does evaporate, but rather slowly. As you pull more air and vapour out you drop the pressure. The ice sublimes and , in doing so , gets even colder.
If you watch this clip you can see the water initially evaporating very quickly, but the rate falls off as the temperature drops.
Fundamentally, you have to supply heat to evaporate the water. It's called the latent heat of vapourisation.
The colder you get it, the more heat you need to add.
A neoprene suit in a vacuum chamber isn't easy to warm (you could try shining light onto it.)
Ash Small
Wed Sept 21 2011, 08:20PM
Generally, to remove water vapour from a vacuum system requires 'bake out'. (elevated temperature for several hours, sometimes days)
Water is probably the biggest enemy of any vacuum system.
Wastrel
Thu Sept 22 2011, 08:43AM
Wastrel Registered Member #4095 Joined: Thu Sept 15 2011, 03:19PM
Don't wetsuits contain closed gas bubbles for insulation? Might cause issues under vacuum. Flowing warm dry air sounds good to me, and any moisture that can't remove isn't going to be giving a cold feeling to the suit anyway.
